Go Back   Home > Forums > Amplifiers > Class D
Old 12th January 2013, 11:53 AM   #3201
i creat IRS 900-1500-2000-3000
i was use IC TC4049
no one worked
Old 12th January 2013, 12:03 PM   #3202
andrewlebon's Avatar
Default hoping against hope
Hi JAY
working on it
warm regards
andrew lebon
[image][/image]"It's Better to try and fail than to never know and always wonder"
Old 12th January 2013, 02:19 PM   #3203
i was use IC TC4049
no one worked
Use Texas Instruments CD4049UBE. I created my own layout based on IRS900 and it worked the first time.
Old 12th January 2013, 02:40 PM   #3204
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi Raj,
use BAL IN for input or you can use as unbalanced mode
UN Balanced Mode:
(+) sign connected to GND(marking shows wrongly)
(-) sign as input with respect to GND
MANOJ
Hi Manoj:
I tried as you mentioned, given input to both -+ points one after another with respect to gnd. Still no sound from Spk.
But if I connect Pin-2 (tl072) to gnd through 220n or resistors like 1K then I get output.
Managed to prepare output inductor as per your instruction. Improved a bit, I used EE cores 24turns 19SWG wire. How many turns for emi reduction coil?
Raj
Old 12th January 2013, 04:10 PM   #3205
schematic and pcb can not work without aplication program
PT2322 project near the end
i replace new ic with PT soon
when complete the project i share that with you friend.
what about AUD600 ?
compelet that ?
Hi Hadi/Manoj/Stewin:
I completed aud600 ver1.0 it works but has some problems. Now trying to solve them
1. If I give audio input to - or + sign with respect to gnd (giving any -/+ to gnd) then there is no output until I give gnd through cap/resistor to pin 2 of tk072 then I get output. Why?
2. My 47ohms resistors are burning instantly, HF is too high but how to control that?
3. I get choppy sound at higher volume.
NB: resistors in pic burned (value is ok) when I used them in 47ohms position.
Have you faced any of such problem? And how you fixed that?
Old 12th January 2013, 06:31 PM   #3206
Default Hi dear friend
Hi friend
is this an amp ?
some time we must wait and try long time. when we wait for along time we can find beter way for our problem.
dont be tierd friend and try more and more. you can do any thing if you want.
best wishes for you friend
Old 12th January 2013, 06:43 PM   #3207
Default thanks friend
i was download data sheet for TC and CD ics
pinout is same
what is the problem ?
i dont know
thanks for your helping
Old 13th January 2013, 11:30 AM   #3208
manojtm is offline manojtm  India
manojtm's Avatar
Hi Raj,
VOLUME control(100K or 50K) side pin connected to 33K resistor from Pin-7 of TL072, center pin from Pin-2 of TL072 and another side from Pin-1 of TL072.
MANOJ
Old 13th January 2013, 11:37 AM   #3209
Hi Raj,
MANOJ
Hi Manoj: Volume is 100K. Connected as per diagram you given. Will recheck to confirm.
Raj
Old 13th January 2013, 11:45 AM   #3210
manojtm's Avatar
Hi Raj,
your VOLUME control wiring is wrong b'cause of that open loop gain effected in TL072 pin-1, so that HF is too high.
MANOJ
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
