| Class D Switching Power Amplifiers and Power D/A conversion |
#3171 | |
may be your filter coil not good.EE core with 24Turns 1mm gap(all) or use T106-2 with 59Turns. HF noise is High that's why 47 Ohm resistor burns. Regards MANOJ |
#3172 | |
use BAL IN for input or you can use as unbalanced mode UN Balanced Mode: (+) sign connected to GND(marking shows wrongly) (-) sign as input with respect to GND Regards MANOJ |
#3173 | |
How to solve input issue? Thanks Raj |
#3174 |
#3175 |
#3176 | |
All legs regards MANOJ |
#3177 |
#3178 | |
0.8mm wire or 1mm wire Regards MANOJ |
#3179 | |
Did you try this on your IRS900? |
#3180 |
any one have the corect picthure for IRS1500 and 900 ?
i mean bottome and layout PIC stewin ... |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
