ucd 25 watts to 1200 watts using 2 mosfets - Page 317 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 5th January 2013, 06:18 PM   #3161
stewin is offline stewin  Kenya
hi akraj, i haven't made the power supply side , but the amp side is o.k. . i am suspecting the issue is like mine .
the 7404 is the issue .
please use the 74hc04 that is the only one which works the dm7404 never worked in my case.
also connect the -ve side of the aux and ir2110 with the main -ve side
Old 5th January 2013, 06:42 PM   #3162
akraj is offline akraj  Bangladesh
HI Stewin:
I am using 74HC04. Okay....how to power up the amp board without power board? There is 3 PIN for BIAS
1. 12 +ve with respect to -ve
2. I don know, what is that for
3. -ve
I can arrange 12+ transfomer for BIAS supply, will connect the "0" to -ve rail. then what?
Please help me out.
Old 5th January 2013, 08:42 PM   #3163
Originally Posted by akraj View Post
HI Stewin:
Please help me out.
it is+12 and the -12 connect to -ve of main powersupply of the amp not 0vlts
also leave the center pin leave it not connected. because it is for protection if you connect it to -ve it will trigger the protection.
lastly change the led light pins it is drawn opposite.
Old 6th January 2013, 05:40 AM   #3164
aman khalsa's Avatar
HI Stewin:
3. -ve
Please help me out.
pls post some pic's may b that can help... thanku
Old 6th January 2013, 05:47 AM   #3165
Hi Stewin: thanks for stepping forward.
Just to cross check, do I need a aux power with 12-0-12? Split supply? Or 12-0 is okay? Is it possible to share a drawing?
Old 6th January 2013, 07:15 AM   #3166
you only need a supply with sinngle rail that is +12 & - 0vlts
but the 0vlts of 12vlts power supply connect it to -ve of amp power supply.
hope the below photos by manoj will help
Old 6th January 2013, 07:55 AM   #3167
Okay, good. I assume the same. Is there any other modification needed if I do not use power board?
Old 6th January 2013, 03:20 PM   #3168
Hi Stewin & Manoj:
Today I managed to run the amp, but there are some issues.
I gave input at PIN-2 (TL072) and then audio comes out from the spk line. But I cannot turn the volume high as the LED lits and goes in to protection mode and immediately releases. But if I use low volume then it is okay.
However, if I give input at -+ (10uF caps) then nothing in spk line.
Looking forward for your help.
Raj
Old 7th January 2013, 04:40 AM   #3169
Hi Stewin & Manoj:
Raj
Besides, 47ohms resistor are becoming too hot, actually bunrns immediately. why this is happening?
Old 7th January 2013, 08:39 AM   #3170
Here are some PIC's
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 12:16 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
