ucd 25 watts to 1200 watts using 2 mosfets
Old 4th January 2013, 03:39 PM   #3151
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Originally Posted by andrewlebon View Post
SOME TESTING PICS on 1500watt load
warm regards
andrew lebon
hello sir... this is amp or smps ?
Old 4th January 2013, 03:40 PM   #3152
JLesterP is offline JLesterP  Philippines
Max SOA for IRFP4227 is 30A at 70V(drain-source) for 100usec pulse duration.
5 ms is too long... protection should kick in at <= 100us, otherwise the mosfet might not survive.
Old 4th January 2013, 04:11 PM   #3153
manojtm is offline manojtm  India
manojtm's Avatar
Hi,Jlester,
OC protect sense should be below 100us so not a problem for MOSFET
i said DC protect sense is 10ms
MANOJ
Old 5th January 2013, 04:28 AM   #3154
Sorry, I misinterpreted your post.
Guess I have to integrate the lm311+ne555 OCP protect in the pcb.
Thanks!
Old 5th January 2013, 05:41 AM   #3155
manojtm's Avatar
Hi Jlester
your class d fsw=250KHz (Period is 4us) so you need 25us sense is max for OC(high current) detect for IRFP4227.so only ne555 is enough for OC sense(15us).Lm311+ne555 is better choice for high freq. operation
Manoj
Old 5th January 2013, 07:24 AM   #3156
akraj is offline akraj  Bangladesh
Hi Manoj:
I managed to repaid both the boards, now the BIAS voltage is okay, it is +ve with reference to -Ve rail.
and Amp board has 6.2 volts at two side, output from 7806 is okay from -ve reference.
now the problem is the 47ohms resistors are burning out immediately when I power on, and I get some noise from main inductor (core from old PC psu).
and the relay of power board triggered one/two times but now it is not switching and connect spk connection.
There is 0.2mil volt at spk out, FETs are just warming.
Please suggest me what to check now and which position to stop 47ohms burn and make the amp workable.
Thanks in advance.
Old 5th January 2013, 11:05 AM   #3157
FET's are ok or not did u chek them.?? and how about ir 2110 ???
Old 5th January 2013, 11:34 AM   #3158
I checked FER's, they are okay. How to check IR2110? Or 7404?
Old 5th January 2013, 02:10 PM   #3159
IRSound is offline IRSound  Germany
check output pulses with scope. or replace them with new one if you know the problem come from this components.
Old 5th January 2013, 05:08 PM   #3160
I replaced all the IC's couple of times but no luck. Need to check with scope but I don have that.
I can manage scope, I guess but what will be the idle data/output from ir or 7404 or op amps.
Now the output relay is not conducting. No dc/AC volt at output, guess this is usual but if I connect Spk directly, touching input pins of op-amps then it starts huge noise even after removing my finger! Around 14dc comes from Spk line. After off/on voltage is gone.
Where I'm making mistake?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
