ucd 25 watts to 1200 watts using 2 mosfets
Old 4th January 2013, 02:34 AM   #3141
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default LOAD TESTING
SOME TESTING PICS on 1500watt load
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 4th January 2013, 03:41 AM   #3142
JLesterP is offline JLesterP  Philippines
Originally Posted by Hadighorbani View Post
i dont like jumpers
I think this is beter
Jumpers are ok.
Why your suggestion is not good? Let's compare it.
1st jumper: is there so that the Logic Gnd (VSS) of CD4049 and Logic Gnd of IR2110 are referenced on the same point.
2nd jumper: the feedback is routed inside the IC instead of routing it along the "noisy" high side gate drive.
3rd jumper: minimizes the path/trace for the current loop in the low side gate drive.
Lester
Old 4th January 2013, 04:13 AM   #3143
HI
thanks for your sharing
why you and other engineer dont creat all things in one board ?
main board dont have OCP ?
for OCP i must creat protection board too ?
thanks
Yes you must create speaker protect with external trigger for it to work.
But I am doubting if the relay is fast enough for it to turn off before the mosfets blow.
I am thinking if this will work?
I will connect the trigger to the SD pin of IR2110, current and voltage will be limited by resistor and zener diode.
Any Ideas?
Old 4th January 2013, 06:08 AM   #3144
Oh, I realized that the SD pin should be connected to logic ground in normal operation, so the circuit above might not work.
I'll revise it
Old 4th January 2013, 07:32 AM   #3145
Hadighorbani is offline Hadighorbani  Iran
sir CPX say to me before the relay is not fast enofe.
i belive him
it is beter to you sir to creat every thing in one board and without relay
you is beter than me
thanks
Old 4th January 2013, 07:35 AM   #3146
Default thanks dear friend
Originally Posted by CPX View Post
Hadighorbani:
Use multisim 11 to open that file. Also you have a huge ground loop on that board and no snubers....
Hi sir CPX
how are you today friend ?
i am happy to see you again here.
thanks for your helping
have nice day
Old 4th January 2013, 08:20 AM   #3147
I think it will be fast if the relay is a solid state/mosfet based.
I think I'll just add a daughter board that can be easily attached through pins.
Old 4th January 2013, 08:30 AM   #3148
Originally Posted by jlester87 View Post
I think it will be fast if the relay is mosfet based.
so expensive
and mosfet have enoufe power ?
Old 4th January 2013, 10:44 AM   #3149
manojtm is offline manojtm  India
manojtm's Avatar
Hi Jlester87,
For DC protect we need 10ms fast is enough if your circuit detect <or=3v dc what i used is <10ms fast one and all other higher current(>10A) rated relays are 18ms fast.
for protecting MOSFET need OC circuit and use at least twice the current rated (25degree) FET.
MANOJ
Old 4th January 2013, 11:12 AM   #3150
Hi Manoj,
Thanks for the info.
I have a Songchuan 801H-1C-S here, it has a 5ms release time. I'll check the SOA of IRFB4227 in its datasheet if it can survive 40A Current within 20ms(worst case).
Iraudamp1 also uses a mechanical relay for OCP, it has a 5ms release time according to its datasheet but it has no documentation for the response of OCP. (unlike IRAUDAMP9 and modified IRAUDAMP5 reference designs)
Lester
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
