Go Back   Home > Forums > Amplifiers > Class D
Old 1st January 2013, 10:54 AM   #3121
Originally Posted by stewin View Post
thanks jlister for sharing . but in the schema like the original ir900d you can't use +/- 65vlts or above comfortably . pls change the cd4049 stage to use three inverter buffer stage like irs1500 or aud ver 1 and 1.1 amps
The schematic is already tested, I created an earlier version of it (attached pictures) however I only used +-51V for the supplies. I don't have a power supply with a higher voltage right now.
If anyone can confirm that the IRS1500 is working for +-75V and up then we can adapt the three inverter buffer stage to the schematic.
Old 1st January 2013, 11:30 AM   #3122
manojtm is offline manojtm  India
manojtm's Avatar
I would like to buy some IRS2092, high power MOSFET, inductors. Can you please let me know where in India I can buy them, Culcatta/Banglaore preferred.
Or any online shop in India to check price and availability.
Raj
Hi Raj,
you can prefer Bangalore.JP street(electronic street) everything you will get.
i am living in KERALA.(malayalam Naadu)
MANOJ
Old 1st January 2013, 12:19 PM   #3123
manojtm's Avatar
Hi stewin,
do not need for three inverter buffer stage(IRS900),when you apply high voltage the buffer and level shift(2n5401) should be aligned properly.i mean you change resistor collector and emitter side of 2n5401 then it will work(10K & 8K2)for higher voltage.
MANOJ
Old 1st January 2013, 12:27 PM   #3124
manojtm's Avatar
Hi Nmos,
do not use very low resistor like 10R for gate drive,(IR2110 will heat)safe run is 40R and not worried about THD (mackie using 47R for @450KHz)
MANOJ
Old 1st January 2013, 12:59 PM   #3125
IRSound is offline IRSound  Germany
Hi Manojtm ,
Could you please start another topic for your design ? and if it's possible , move AUD600 related posts to that topic..
anyway , how can i have your amp's schematic ? because i want redesign board and change some component or their footprints etc.
i think that's because mackie use Class-d for LF drive..
Old 1st January 2013, 01:28 PM   #3126
stewin is offline stewin  Kenya
Originally Posted by manojtm View Post
Hi stewin,
MANOJ
thanks manoj GOD bless you .
Old 1st January 2013, 03:03 PM   #3127
manojtm's Avatar
Hi IR,
yes its LF i agree that but its drive MID also (MID BASS)
MANOJ
Old 1st January 2013, 03:27 PM   #3128
aman khalsa's Avatar
hello sir manoj can u pls start a new thread for ur amp ???? where can we talk about only about ur amps. thank u
Old 1st January 2013, 04:07 PM   #3129
happy new year to all diy audio members
Old 1st January 2013, 04:59 PM   #3130
Talking happy new year
pcb nice congratulations, good job. how much power rate (w), a query that design is Nanotechnology mo.
happy new year to all forum
:c heers:
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
