ucd 25 watts to 1200 watts using 2 mosfets
Old 31st December 2012, 06:46 PM   #3111
stewin is offline stewin  Kenya
Originally Posted by Hadighorbani View Post
Hi stewin
i use 74HC04 for ver1.1
but it was not worked.
why ?
i got the ic sn74hc04n and it worked very well ver 1.1.please recheck your board .
happy new year diy audio world
and a happy and a prosperous new year
Old 1st January 2013, 05:54 AM   #3112
akraj is offline akraj  Bangladesh
Hi Stewin:
I used IRF630 in power board hope this is okay as other version used 10N20!
Is the any issue if I use 10uF 16v capacitors?
Raj
Old 1st January 2013, 07:07 AM   #3113
Originally Posted by akraj View Post
Hi Stewin:
Raj
where specifically in board?
Old 1st January 2013, 07:19 AM   #3114
Originally Posted by jlester87 View Post
I'll gonna share my layout based on IRS900 / IRAUDAMP1.
I put the bias supply onboard and put an external OCP trigger so that the speaker protect will activate in case of short circuit.
Speaker protection circuit included.
Just don't remove my name when you etch the PCB. It gives me the credit for my effort.
Happy new year everyone
thanks jlister for sharing . but in the schema like the original ir900d you can't use +/- 65vlts or above comfortably . pls change the cd4049 stage to use three inverter buffer stage like irs1500 or aud ver 1 and 1.1 amps
Old 1st January 2013, 08:20 AM   #3115
I used 16V caps, marked with red circle.
Old 1st January 2013, 08:51 AM   #3116
IRSound is offline IRSound  Germany
HAPPY NEW YEAR GUYS
Hi Manojtm ,
Could you please start another topic for your design ? and if it's possible , move AUD600 related posts to that topic..
anyway , how can i have your amp's schematic ? because i want redesign board and change some component or their footprints etc.
IRSound
Old 1st January 2013, 09:22 AM   #3117
manojtm is offline manojtm  India
manojtm's Avatar
Hi Raj,
Near IR2110 use 10uF/63v(for low voltage Max.55V) or 1uF/100V(for Max.90V)
all other which you specified can use 16v range.
MANOJ
Old 1st January 2013, 09:33 AM   #3118
Thumbs up Thanks Manoj
Originally Posted by manojtm View Post
Hi Raj,
MANOJ
Hi Manoj:
I would like to buy some IRS2092, high power MOSFET, inductors. Can you please let me know where in India I can buy them, Culcatta/Banglaore preferred.
Or any online shop in India to check price and availability.
Raj
Old 1st January 2013, 09:54 AM   #3119
exflaco is offline exflaco  Armenia
HAPPY NEW YEAR 4 all diyers
Old 1st January 2013, 10:07 AM   #3120
NMOS is offline NMOS  Germany
NMOS's Avatar
Im new in Class D what does it mean to change CD4049 ? can you share schematic ?
I have this IRS 900 ,.. can work with + / - 80V or not ?
look pic
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
