ucd 25 watts to 1200 watts using 2 mosfets - Page 311 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 29th December 2012, 01:05 AM   #3101
stewin is offline stewin  Kenya
hi manoj i have managed to configure cd4049 . now the amp is working o.k .
your amp has great clarity in mids comparing to irs series amps. congratulations.
about the output inductor it is the same case as irs amps . i started with 64turns etd 42 but outputs were hot . so i switched to 22turns etd42 they became cool . my output voltage is +/- 48vlts; outputs are irfp250n, gate resistor 39ohms .
>>>the 3.3kohms 3watts resistors for dropping voltages 6.3volts get hot i don't think they will handle +/-85vlts.
now i have to find the ttl ic 74hc04 series because the sn74s04n did not work in my case.
thank manoj for such a good amp
Old 29th December 2012, 04:46 AM   #3102
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
thank you very much for your appreciation.
for good low and mid use T106-2 0.8mm wire 59Turns.
use 3.3K/5w(75V supply) it will heat little but not burn
MANOJ
Old 29th December 2012, 05:15 AM   #3103
manojtm's Avatar
Hi stewin,
SN74S04N package is different (W package)
VCC= Pin 4
GND= Pin 11
Pin 1=1A, Pin 14=1Y
Pin 3=2A, Pin 2=2Y
Pin 6=3A, Pin 5=3Y
Pin 7=4A, Pin 8=4Y
Pin 9=5A, Pin 10=5Y
Pin 13=6A, Pin 12=6Y
My design using DM74S04 fairchaild one
MANOJ
Old 29th December 2012, 06:43 AM   #3104
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi stewin,
MANOJ
Hi Manoj: I'm about to finish my one.
Old 29th December 2012, 07:39 AM   #3105
Hi stewin,
VCC= Pin 4
GND= Pin 11
Pin 1=1A, Pin 14=1Y
Pin 3=2A, Pin 2=2Y
Pin 6=3A, Pin 5=3Y
Pin 7=4A, Pin 8=4Y
Pin 9=5A, Pin 10=5Y
MANOJ
Hi: I have SN74HC04, will it work?
Old 29th December 2012, 08:04 AM   #3106
yes it will work . hadi used it and it his amp is o.k
Old 29th December 2012, 04:29 PM   #3107
Just need couple of capacitors for amp board, 10p, 10n etc then it will be ready for firing up! I used IRF630 in power board hope this is okay as other version used 10N20!
Is the any issue if I use 10uF 16v capacitors?
Old 29th December 2012, 04:40 PM   #3108
Default Where to find aud600 parts at India
Hi Manoj: I would like to buy some IRS2092, high power MOSFET, inductors. Can you please let me know where in India I can buy them, Culcatta/Banglaore preferred.
Or any online shop in India to check price and availability.
Raj
Old 30th December 2012, 09:31 AM   #3109
Default Hi to all
Hi stewin
i use 74HC04 for ver1.1
but it was not worked.
why ?
Old 31st December 2012, 03:59 PM   #3110
aman khalsa's Avatar
happy new yeat to all my diyers.....
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
