ucd 25 watts to 1200 watts using 2 mosfets
Old 27th December 2012, 07:38 AM   #3091
stewin is offline stewin  Kenya
Originally Posted by manojtm View Post
Hi All
IRS4K5
+95V,-95V 2 Ohms load only.max Current= 47A
then why we need a 3 pair MOSFET??? a single 75A 25 degree 100nC MOSFET will do 4K5 output.
My AUD600 with IRFP4668 gate resistor 39R / 47R with supply +90V -90V will do 4000W 2R load
MANOJ
Hi manoj i am about to finish and test your amp i will post photo and my review later.
Does it mean if you bridge aud600 with the right fets at 4ohms you will get an output of 8kwts ?
Old 27th December 2012, 12:32 PM   #3092
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default VIPER12A
Hi Irvynejay
greetings viper12a giving 60 volts dc no 15.5 volts smps is working i used top244 ic for 15 volts pls check
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 27th December 2012, 12:35 PM   #3093
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
pls check mail to check faults
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 27th December 2012, 12:36 PM   #3094
Default VIPER12A
still lots of work on pcb to be completed
warm regards
andrew lebon
Old 27th December 2012, 03:49 PM   #3095
Hi manoj i just finished aud600 amp but it is not working ,it is emitting dc on outputs. I have cross checked the pcb
i used irfp250n for output fets , ic is sn74s04n my voltage is +/-48vlts and small adaptor 12volts 1.5amps . i did not make the power aud600 side i was eager to hear the amp . Thanking you in advance stewin
Old 27th December 2012, 05:33 PM   #3096
akraj is offline akraj  Bangladesh
Hi: Stewin, I also made this aud600 and soldering parts!
By the way which version you used?? As per hadi, version 1.0 worked.
hope to share my experience shortly.
Raj
Old 27th December 2012, 06:28 PM   #3097
Raj
I think mine is ver1.1
Old 28th December 2012, 12:29 AM   #3098
i am using aud600 ver1.1
is this ic the one causing my amp not to work? sn74s04n
by the way my output inductor is etd42 with 64turns . below the boards and the schema i used .
Old 28th December 2012, 05:07 AM   #3099
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
without Power board it will not work.you need miner changes to do then it will work without power board.
(a) BIAS (-) pin to -75V supply
(b) remove IN4148 from NE555 IC connected to PIN 11 of IR2110.(now OC will not work)
(c) +12V for BIAS supply with respect to -ve rail supply
(d) Provide DC Protect
My AUD600 rev1.0,1.1 & 1.2 all are working one
MANOJ
Old 28th December 2012, 06:42 PM   #3100
hi to all i also made the 4k5 and tested it . it worked o.k perfectly .but i prefer irs900d in mids. but sound is o.k . i used irp250n one pair only , gate resistor is 100ohms, voltage is +/- 67.9 vlts the outputs are cold as ice and are not on mounted on any heatsink. my load is 12ohms speaker . inductor is 24turns ei core from old pc power supply.
what i noted is with large output inductor like 60uh both irs 900 and 4k5 the output fets get hot so about 20uh i found to work out o.k.
looks like i am very unlucky with aud600 still not working . i will try to change the 7404 and use cd4049 i suspect the ic has issues . and there is only one vendor with that part in my country . so i will try my luck with cd4049 .
of course i will change the pins
low quality pics . but better ones later
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
