ucd 25 watts to 1200 watts using 2 mosfets
Old 20th December 2012, 07:40 AM   #3071
stewin is offline stewin  Kenya
Default thiechay 900d version
Originally Posted by thienchay View Post
Hello all Diyer
This my new class D , and i 'll checking it soon .
hi all has anyone tried thienchay irs900 amps with high voltage like +/-75vlts and above?
Old 21st December 2012, 09:49 AM   #3072
akraj is offline akraj  Bangladesh
Smile Aud600
Hi Manoj & all: This aud600 pcb, waiting to each. Special thanks to Manoj.
Old 21st December 2012, 04:20 PM   #3073
NMOS is offline NMOS  Germany
NMOS's Avatar
IRS 4K5 and IRS 900
what is Bias Voltage ?
Can IRS 4K5 work with +/- 90V
Old 21st December 2012, 09:21 PM   #3074
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Nmos
greetings
1 bias voltage 12 volts i use 12 volt 2 amp smps
2 IRS4K5 use FDA69N25 for +/- 90v dc
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 22nd December 2012, 09:09 PM   #3075
Hadighorbani is offline Hadighorbani  Iran
Hi to all
i try IRS 900-1500-2000-3000 D
which one off resistor was for OSC ?
what about filter ?
I want to use IRFP250N
IRFB31N20 was finish in store.
sorry for me.
thanks
Old 23rd December 2012, 05:17 AM   #3076
The resistor for oscillation in irs900 is the one 1k between the two 1nf near the amps input.the gate resistors has to be 100ohms if you are using irfp250n . The inductor try 80uh .the irs900 is not friendly to high voltage . Have fun.
By the way hadi , what voltage did you use with your aud600, and how was the sound quality?
Old 23rd December 2012, 07:41 AM   #3077
Hi sir stewin
some one say to me sir is used for soldier and commander
i change some resistor for + - 30 VDC
i use to + - 50 VDC too
sound is very good in quality and power but i dont have power full smps and i realy need that
sir manoj amp is very compelet in protection and every things but it was a littel big
creat ver 1.0
it was work so good
i have T106-2 and 0.8 mm wire
how much turn for IRS series dear friend ?
have nice time
Old 23rd December 2012, 10:32 AM   #3078
Ho to all
IRS series PCB not good
sir manoj and apex PCB is so beter
Old 24th December 2012, 06:15 AM   #3079
Noobieme25 is offline Noobieme25
Originally Posted by Hadighorbani View Post
Ho to all
how about irs2000d? its design is ok?
Old 24th December 2012, 07:48 AM   #3080
NMOS's Avatar
Cant buy right Mosfets because not stock by local supplier, its X-mas time
order takes long time and I want test IRS4K5 now
Have only in Stock IRFP460
IRS4K5,....with IRFP 460 what will happened for test ?
Music comes out or amplifier not working or firework ?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
