ucd 25 watts to 1200 watts using 2 mosfets
Old 18th December 2012, 02:18 PM   #3061
manojtm is offline manojtm  India
manojtm's Avatar
what is the value off gate resistor ?
Hi Hadi,
39 Ohm OR 47 Ohm
if need a more power for your AMP use high voltage like 55V OR 65V OR 75V. use LPS
are you need a CAR SMPS???
MANOJ
Old 18th December 2012, 04:18 PM   #3062
stewin is offline stewin  Kenya
Hi all pls help . The irs900d i made , i tested with +/-45vlts everything was o.k except ir2110 heating which was solved by a small heatsink . When i added the voltage to +/-75vlts the amp works for a few minitues then distorts badly all channels behave the same. the components are exactly the ones posted in irs900d . When i reduced the voltage to +/- 39vlts all channels are working o.k .
The amp has 3channels , my inductor is etd42 20turns . Outputs are irfp250n with 100ohms gate resistor . the aux voltage i used irf640 for each channel to produce the +12vlts the main capacitor is 100vlts x 1000uf x 4pieces.
Old 18th December 2012, 04:23 PM   #3063
Hadighorbani is offline Hadighorbani  Iran
Default THanks to sir manoj
Originally Posted by manojtm View Post
Hi Hadi,
39 Ohm OR 47 Ohm
MANOJ
Hi
yes
i want use AUD600 in my car
Old 18th December 2012, 05:03 PM   #3064
kirubakaran is offline kirubakaran  India
Default hi stewin,
irs900d is using 2inverter buffer (cd4049) pls change the schemantic pcb layout to 3 inverter buffer stage.
Old 18th December 2012, 09:05 PM   #3065
Please do you have the schematic or the correct pcb layout of irs900d which can work with hi voltage like +/-80vlts comfortably with irfp250n
Old 19th December 2012, 07:44 AM   #3066
hi manoj .
have you tried your amp aud600 with hi voltage like +/-85 vlts outputs using irfp250n, and has it worked well without any issues?
Old 19th December 2012, 08:19 AM   #3067
Default hi stewin,
hi stewin,
greetings,
i dnt have schematic i was try irs900 but its failed in high voltage, the i try irs1500 its work perfect with +- 75 voltage. small difference between irs900 and irs1500.
Old 19th December 2012, 09:10 AM   #3068
manojtm's Avatar
hi manoj .
Hi stewin,
yes it can handle 90V max. spk 8R load. tested 87V supply working good. fsw=@250KHz 8R spk load
MANOJ
Old 19th December 2012, 10:05 AM   #3069
manojtm's Avatar
Hi Stewin,
may be your filter, its saturated due to high voltage. T157-2 for high voltage application.
T106-2 for max.65V supply.
MANOJ
Old 19th December 2012, 07:01 PM   #3070
Hi Stewin,
MANOJ
I used etd42 20turns 1mm single copper wire
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
