| Class D Switching Power Amplifiers and Power D/A conversion |
#3021 | |
i have two channels and i am using one adapter of 12vlts to serve both channels . but i have no noise issues and the amp is clear . the main voltage is +/-45vlts gate resistors are 100ohms output fets are irfp250n they are cool even though i have not mounted them on a heat sink. when i push the amp real hard at that voltage the outputs only warm up a little. i will juice it up to +/- 80vlts |
#3022 |
stewin what is your inductor value?
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend |
#3023 |
Hi Hadi,
mistake: do not use Lm7812 for TTL ics (74HC04) it is LM7806 or LM7805 otherwise it will damage. re check IC damaged or not. how much turns for T106-2?? picture shows @ 80 Turns is it? you can reduced to 59 turns. connected power supply not mentioned(no picture) Regards MANOJ |
#3024 |
Hi sir manoj
yes 80 turn i have resistors 820 ohm and 680 ohm with 1% telorance for changhe the FREQ i use LM7806 like your shematic in board i whant use LM7812 for bias section not in the board amp is alive and TTL IC is work good how can i change the curent option on your board? |
#3025 | |
i will send the schematic regards Manoj |
#3026 |
Hi Hadi,
Over current (I) = 550mv/0.04 Ohm x 1k5+1k/1k = 34A ![]() ![]() remove resistor R2 and R4(1K) OC will be @13A Regards Manoj |
#3027 |
#3028 |
#3029 |
sir manoj
in your over current protection pdf file you write from filter. which filter you mean ? amp out put filter or your power board big capasitors and diod brighe filter? and can you please share a beter form of your formula for over current section like this over current(I) = V .../ R... * R1 + R4 / R2 or some thing like this ? thanks |
#3030 | |||
schematic shows over current section only.not "leg 5 of 555 ic " it is BIAS center pin "s". Quote:
0.1R*3= 0.04 Ohm--- Current resistor(R) R1=R3 --- 1K5 R2 & R4= 1K I = V/R x R1+R2/R2 Quote:
Regards MANOJ |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
