ucd 25 watts to 1200 watts using 2 mosfets
Old 5th December 2012, 07:27 AM   #3001
Hadighorbani is offline Hadighorbani  Iran
Default Hi
Originally Posted by NMOS View Post
short question
what amp do you have build ?
can you send me schematic
this amp is sir manoj amp ver 1.0
nobody have schematic for this amp
Old 5th December 2012, 07:20 PM   #3002
stewin is offline stewin  Kenya
hi hadi regarding your question : i etched manojs amp but i did not make it because of complex issues i wanted a simple powerful amp.
i made irs 900d it is simple and very silent i think because it is non ucd that is why it is noiseless . but i plan to use it with manoj power supply board because of the oc protection in manoj power supply board. will post pictures soon
Old 6th December 2012, 06:29 AM   #3003
manojtm is offline manojtm  India
manojtm's Avatar
i try turn on your amp without power section
i use one lm7812 for bias but it dose not worked. why?
Hi Hadi,
you should connect -75v(or your supply voltage what you given) supply to PIN 13 of IR2110.
and your car cd player you connected from 12V BAT or SMPS(12V)???
MANOJ
Old 6th December 2012, 06:38 AM   #3004
manojtm's Avatar
Hi Stewin,
IRS900D,IRS2000,IRS3000 and my AUD600 all are delta sigma type UCD(self oscillated).
these are discrete version of IRS2092 chip.
MANOJ
Old 6th December 2012, 11:18 AM   #3005
akraj is offline akraj  Bangladesh
Default SMPS
Originally Posted by manojtm View Post
Hi Hadi,
MANOJ
Hadi:
You can check the bellow design for SMPS.
1000W SMPS Based on IR2110
Raj
Old 6th December 2012, 03:43 PM   #3006
thanks to all friends
Old 6th December 2012, 03:49 PM   #3007
Default thanks to sir manoj
Hi Hadi,
MANOJ
Hi sir manoj
i use + - 30 VDC for your amp
i dont know what you mean
i used 12v DC and conect the + line to + leg of bias and connect - line to -leg off bias.
i donot connect any thing to center leg of bias
what is my wrrong ?
my car cd player connect to 12V BAT
my car smps is not issolated
thanks
Old 7th December 2012, 12:40 AM   #3008
SERGIODS is offline SERGIODS  Peru
Thumbs up design
Originally Posted by stewin View Post
hi all the correct artwork of irs900d
this design are:
NANOTECHNOLOGY:
Foros de Electrónica - Comunidad Internacional de Electrónicos
Primeira Página - Primeira Página
This forum is not what its name is.
Old 7th December 2012, 05:18 AM   #3009
manojtm's Avatar
what is my wrrong ?
Hi Hadi,
For BIAS connection +12V line connected to (+) sign and -12V/GND line connected to (-) sign and (-)sign should be connected to -30V supply(without this amp will not work). no connection for center leg.
do not use same 12v for bias and CAR CD Player, it will damage your amp/cd player. use separate supply.
MANOJ
Old 7th December 2012, 09:09 AM   #3010
Hi Hadi,
MANOJ
my car smps was not isolated
input gnd and output gnd is same in car converter then amp gnd and cd player gnd and bias gnd is same
what can i do ?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
