Go Back   Home > Forums > Amplifiers > Class D
Old 30th November 2012, 11:52 AM   #2981
manojtm is offline manojtm  India
manojtm's Avatar
what is the switching frequency?
@250KHz
MANOJ
Old 30th November 2012, 12:56 PM   #2982
stewin is offline stewin  Kenya
thanks manoj you are a saint
Old 1st December 2012, 06:20 AM   #2983
manojtm's Avatar
Hi ALL,
IRFP250 can switch up to 1MHz(1000nS). not tested with class d amp, simple oscillator used for testing(supply 24V)
MANOJ
Old 1st December 2012, 04:50 PM   #2984
Default IRS2000D by Thienchay
To chago25,please check
Old 2nd December 2012, 11:43 AM   #2985
hi all the correct artwork of irs900d
Old 2nd December 2012, 12:58 PM   #2986
Default IRS 2000/3000
Hello, in this version we built four pieces, none work, even planting corrections pieces notified by the author.
enter only periodic oscillation and works only with two IRFB 2772
I say this because others have no trouble on this scheme
Old 2nd December 2012, 01:04 PM   #2987
Default irs 900D
Hello, in this version we built four pieces, with two IRFB 2772 powered by 75V, with small changes works perfectly. frequency is 450 KHz
which is the rated power of the amplifier and is the standard audio input
Old 2nd December 2012, 01:14 PM   #2988
hy ,jancso IRFB4227,450Khz ....
Old 2nd December 2012, 01:19 PM   #2989
Originally Posted by manojtm View Post
Hi ALL,
MANOJ
will this be true at +/-60vlts
Old 2nd December 2012, 01:19 PM   #2990
Default ionutzxpo
give 450 kHz, with your help and many thanks for the support given to you
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2013 diyAudio
