| Class D Switching Power Amplifiers and Power D/A conversion |
#2961 | |
I also given your file (ver 1.1) to make PCB. Should I halt that untill you correct the design- if needed? Thanks Raj |
#2962 |
Hi Hadi,
sorry not 80Turns its 70Turns typing mistake Regards MANOJ |
#2963 |
Hi Hadi,
AUD600-Rev1.1 there is nothing see any error on PCB.cross checked every track,only i changed 2x 47k 0.25W replaced to 1x 100K 1W and 1k 1% changed to 1K trim pot and added temp switch provisions For this trim pot do not set to zero Ohms (shorted) minimum value is @200 Ohm.And first setup is, trim pot set to 1K value. other wise remove trim pot and fix a 1k 1% resistor. I think you are done a mistake something has happened may be component value change or track shorted etc... re-check again Regards MANOJ |
#2964 |
Hi
you change 10uf 100v cap with 1uf 100v too and some chage too near ir ic PLZ wait for stewin amp if he have like me error then must chek again i dont use trimer i use 1k 1% and 1k 1w i must send to you my picture i use 80 turn around T106-2 and conect the filter to board i dont here like this before and every thing is good and cold. not heat any things the sound is so cleare and very good i must say very very very thanks sir manoj i like to have your new vertion can you please send it to my email ? thanks dear friend |
#2965 | |
YES I AGREE THAT, BUT NOTHING WILL HAPPEN WHEN YOU CHANGE THE VALUE 10uF/100V TO 1uF/100V THIS IS VB SUPPLY FILTER OF IR2110 FOR USING HIGH SUPPLY ie.+75V OR MORE YOU NEED TO REDUCE THE VALUE THAT IS WHY I REDUCED TO 1uF/100V. NOW YOU CAN INCREASE THE FREQ. TO 300KHZ AND TEST IT FOR THIS FILTER YOU REDUCE TO 47uH. REGARDS MANOJ |
#2966 |
Hi sir manoj
IRFP250 work in 250 KHZ do you want use it for 300 KHZ ? why ? how can i creat 47uH with T106-2 ? |
#2967 |
Hi hadi,
irfp250 you can use up to 330khz its for only test, and the quality also increase regards manoj |
#2968 |
how can i creat 47uH filter ?
how much turn aroud the T106-2 with 0.8mm wire ? what about the resistor value for change the FREQ 300KHZ ? |
#2969 | |
T106-2 winding Calcultion (uH = n^2 x Al /1000) so 47uH = n^2 x 13.5 /1000 59 Turns for 47uH resistor, i don't know the correct value(don't remember). 820 Ohms or 680 Ohms Regards MANOJ |
#2970 |
thanks sir manoj
i need a preamp for your amp do you have any sugestion ? i need to reduce noise in your amp thanks |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
