ucd 25 watts to 1200 watts using 2 mosfets
Old 25th November 2012, 07:29 AM   #2951
manojtm is offline manojtm  India
manojtm's Avatar
in bias between - and + leg we have 11.75 VDC
Hi Hadi,
OK. check the voltage given for TLO71 & 72 IC (GND and -6V, GND and +6V)
it will took max 7.5mA cuurent (35V supply 3.3k/3w you will get 10mA)
if it is below 5V you need to change the resistor value to 1k/3w.
My new AUD600 rev.1.3 i used TL783 ic for +6v and relay +12v supply.
regards
MANOJ
Old 25th November 2012, 08:48 AM   #2952
Hadighorbani is online now Hadighorbani  Iran
Default thanks to sir manoj
ok
Old 25th November 2012, 10:10 AM   #2953
Hi sir manoj
it was in negative 5.54 and in pasetive is 5.24 VDC
Old 25th November 2012, 12:19 PM   #2954
How can creat 25uH selfe arund the ETD29 core for reduse EMI sir manoj amp ?
Old 26th November 2012, 04:56 AM   #2955
manojtm's Avatar
Hi Hadi,
25uH is used to reduce EMI in output wave. Initially you do the AMP work perfectly. you don't worried about output filter noise . you need to shield for reduce this.
Manoj
Old 26th November 2012, 05:36 AM   #2956
manojtm's Avatar
Hi Hadi,
0.6mm 24 Turns for 25uH. both winding start point i marked (big dot).first you wound 70uH after complete then 25uH
MANOJ
Old 26th November 2012, 09:50 AM   #2957
Hi sir manoj
ver 1.1 was not work
i thing some thing was error in that board
i creat ver 1.0
it was work good for 2 hour
i have 0.8mm wire
i creat 25 uH with 22 turn of 0.8mm wire
i creat 25uH and after that creat 70 uH with 40turn of 0.8mm wire
when i conect the 25uH to the amp board then ETD29 go to truble hot just in several secound and mosfet too and 4.7 ohm resistor near the relay burn
without 25uH amp work good even without mosfets heatsing
what about in your new vertion ?
Old 26th November 2012, 10:14 AM   #2958
can i use T106-2 for this amp sir manoj ?
say to me how can i creat filter self with this core ?
Old 26th November 2012, 10:32 AM   #2959
manojtm's Avatar
Hi Hadi,
Thanks for pointing errors(rev. 1.1) I will re-check the PCB. and get back to you
Yes you can use 106-2. use only single winding.
T106-2 you need 80Turns for @65uH
I think your winding polarity reversed.
MANOJ
Old 26th November 2012, 10:51 AM   #2960
yes
i thing too
i creat that yesterday
that time you dont have pm for me
thanks dear friend
do you creat ver 1.3 ?
i dont have a good and power full smps
i realy need one for best testing your amp sir.
thanks for every thing you do.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
