ucd 25 watts to 1200 watts using 2 mosfets
Old 23rd November 2012, 10:45 AM   #2931
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
not for njm for NE5532
Old 23rd November 2012, 12:34 PM   #2932
Hadighorbani is offline Hadighorbani  Iran
ok
Old 23rd November 2012, 02:01 PM   #2933
Hi sir manoj
DC offset is -0.001 now
i use 1k 1% resistor
i dont have DSO or CRO
relay steal have problem
some time was conect and some time was disconect
i steal use + - 35 VDC for input amp
i have noise steal like hissssssss
the relay was disconect the band
i paraleld a LED with relay self for know when it is work
what can i do now ?
Old 23rd November 2012, 02:17 PM   #2934
when i conect the power after 2 secound the relay work and conect amp to band but after 1 second the relay is turn off and disconect the exit from band and core start to creat noise like hissssssssss.
Old 23rd November 2012, 02:38 PM   #2935
i change all IC
is this right 74HC04 ?
Old 23rd November 2012, 02:40 PM   #2936
i connect input signal
shild conect to GND
+ signal connect to + input
nothing conrct to - input and it is not connect to GND
right ?
Old 23rd November 2012, 03:14 PM   #2937
Default thanks to sir manoj
Originally Posted by manojtm View Post
Hi Hadi,
check with this
regards
MANOJ
Hi sir manoj
this layout is deferent with ver 1.1
why ?
is this ver 1.0 ?
thanks
Old 23rd November 2012, 04:01 PM   #2938
one of the 47 ohm resistor creat smoke
resistor near the ETD29 core
the relay was conect and disconect meny time when i tuch the 100k volume legs
Old 23rd November 2012, 04:05 PM   #2939
are you finished you amp stewin ?
Old 23rd November 2012, 05:54 PM   #2940
stewin is offline stewin  Kenya
not yet. i,m busy but i will try to finish it. next week
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
