| Class D Switching Power Amplifiers and Power D/A conversion |
#2911 | |
use min. 22uH and Max.220uH for reducing emi and AC50Hz line noise.(recommended 68uH) ok use zener 6.2V 1mm gap all why you are waiting for 1K 1% resistor for testing use 1K 5% one regards MANOJ |
#2912 | |
all are self osc.(delta sigma modulation) type class d. my design is low emi and low noise one Regards Manoj |
#2913 | |
for low THD use MOSFET 70/100nc one gate resistor use recommended the manufacturer use fsw = 400KHz/450KHz to get smooth sine wave (that will reduce filter size and capacitor value)do not compare with 250KHz range. for class d start with 80KHz to 500KHz.(new generation MOSFET) for 100KHz use big filter ie. @300uH and big capacitor ie. 30uF/250V to reduce noise and wave shape comparatively good fsw = 400KHz filter @22uH capacitor 0.47uF/2250V to achieve this you need good PCB, supported MOSFET, good filter and components. for DIYs start with 125KHz (it is easy) and try with 250KHz switching(not easy) My design you can go up to 400KHz range Regards MANOJ |
#2914 |
ok
i use 1k 5% gap must be just in center leg or all ? i have 170uH can i use for all self ? |
#2915 | |
all leg 1mm gap regards manoj |
#2916 |
can i use 170 uH for all self ?
#2917 | |
for output filter ? No. for fsw=@250KHz use max 90uH. good 62uH or 70uH fsw=@180KHz or 150KHz you can use 170uH filter for DC filter yes you can use 170uH Regards MANOJ Last edited by manojtm; 21st November 2012 at 08:18 AM. |
#2918 |
you use 3 pcs 220uH 1/4w self in your pcb
one in power and two in amp. i was said can i replace 170uH with 220uH in your board ? thanks |
#2919 |
what is this meaning?
( the speakers should also be connected in anti-phase ) |
#2920 | |
3 x 220uH for DC filtering(AC 50Hz and EMI filter). Regards MANOJ |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
| Page generated in 1.17209 seconds (100.00% PHP - 0% MySQL) with 10 queries |
