ucd 25 watts to 1200 watts using 2 mosfets
Old 14th November 2012, 04:11 AM   #2851
Workhorse is offline Workhorse
Workhorse's Avatar
Happy Diwali to you also.
No email from you.
Old 14th November 2012, 06:02 AM   #2852
Hadighorbani is offline Hadighorbani  Iran
Hi friends
i want to creat sir manoj class d amp
AUD600
that have ETD29 core
i can find it here
thanks for your good amp sir MANOJ
thanks for your reply dear friends
have a good day
Old 14th November 2012, 09:44 AM   #2853
Hi sir manoj
How are you today my friend?
i will buy your AUD600 amp parts
please help me for these questions
you say to me one of the resistor are 1%
wich one is?
i know it value is 1k but i want know wich one in your board
can you please share a picture for core gap?
can i replace stta806 with your mur1560 ?
i want use this amp in 300watt rms 2 ohm with + - 30 VDC
what is this R1* in volume section ?
i want replace 2n3906 and 2n3904 with BC type. is this ok ?
what is this 10N20 ?
can you please say complet part number for this ?
what is this near relay ? 4E7 2W
what is the voltage of capasitors ?
L 431 is TL 431 ?
what is the value of capacitors near the 10N20 ?
please reform the PDF file and send it to me for these things and share again in topic
thanks so much my dearest friend
have a good day
Old 14th November 2012, 09:50 AM   #2854
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default smps
Hi Irvynejay
greetings remaining pcb of smps you have osscilator pcb
warm regards
andrew
"It's Better to try and fail than to never know and always wonder"
Old 14th November 2012, 10:19 AM   #2855
SNY is offline SNY  Hungary
Dear Andrew/
It is this form life-threatening PCB.
The leakage current path is too small ... (minimum 8 mm between the primary and secondary side)
1mm -- > 8 mm !
Old 14th November 2012, 10:27 AM   #2856
Hi Sny
greetings nice ADVICE safety is first priority for diyers SMPS supplies can be lethal
advice greatly appreciated as smps very new to me
warm regards
andrew
Old 14th November 2012, 03:38 PM   #2857
kirubakaran is offline kirubakaran  India
hi, every one,
i have etd 29 with 1mm gaped core. how many tuns to 22uh inductor..
thanks in advance
Old 14th November 2012, 06:14 PM   #2858
stewin is offline stewin  Kenya
Originally Posted by kirubakaran View Post
hi, every one,
thanks in advance
18turns
Old 14th November 2012, 07:25 PM   #2859
exflaco is offline exflaco  Armenia
Andrew your request this is a Crown LT series amps, schem smps powertech clon
Old 14th November 2012, 10:23 PM   #2860
Hi Exflaco
greetings THANKS for sharing
warm regards
andrew
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
