ucd 25 watts to 1200 watts using 2 mosfets
Old 11th November 2012, 07:09 PM   #2831
Hadighorbani is offline Hadighorbani  Iran
is TC4420 enoufe for drive 5 IRFZ44N ?
Old 11th November 2012, 08:21 PM   #2832
fra is offline fra  Slovenia
For 4 or even 5 is enough 500mA. they can directly drive the SG3525 on 50khz
Old 12th November 2012, 04:14 AM   #2833
thanks fra
Old 12th November 2012, 04:44 AM   #2834
manojtm is offline manojtm  India
manojtm's Avatar
Hi
i need mosfet driver for drive 5 + 5 IRFZ44N for this smps
any sugetion?
Hi Hadi,
Use IRF3205 x 2 with 47 Ohm gate resistor freq=80KHz or 100KHz. Primary turns 3+3
MANOJ
Old 12th November 2012, 11:35 AM   #2835
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default ir2104
ir2104 IOR DRIVER
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 12th November 2012, 03:27 PM   #2836
Default thanks to manoj
Originally Posted by manojtm View Post
Hi Hadi,
MANOJ
Hi my dear friend
it is not posible to handel 110A in TO220 case.
you mean i must use 4 IRF3205 ?
can this handel + - 30VDC 20A ?
thanks for your reply
Old 12th November 2012, 06:50 PM   #2837
If someone wanted to build this amp, one 1N4148 diode has wrong direction.
File Type: jpg Amplificador Classe-D pg 74 components irs4k5 pop.JPG (219.3 KB, 1372 views)
Old 12th November 2012, 10:25 PM   #2838
don2007ksa is offline don2007ksa  Philippines
hi fra, what type of toroidal core can i used on this design? it may handle a large amount of current is it a low or high permeability type?any idea and how about the outside & internal diameter, thickness of this core that your going to used?is it available in the market?thank's
Old 12th November 2012, 10:29 PM   #2839
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I use a t106-2 core.
You might need a slightly bigger core for your current needs.
the t106 is 1.06 inches diameter and the -2 is the core type.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 13th November 2012, 02:47 AM   #2840
Default HELLO
Hi Nano
greetings NICE WORK
warm regards
andrew lebon
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
