ucd 25 watts to 1200 watts using 2 mosfets
Old 9th November 2012, 08:10 AM   #2811
Hadighorbani is offline Hadighorbani  Iran
Default thanks to manoj
Originally Posted by manojtm View Post
Hi andrew,
EPCOS ETD49 is better than torroid core
MANOJ
how many power (watt) ETD49 can handell?
ETD59?
ETD44?
is EE core beter than ETD core?
Old 9th November 2012, 10:40 AM   #2812
manojtm is offline manojtm  India
manojtm's Avatar
HI my friend
how can i creat over temp protection?
hi hadi,
use with any thermal switch 75 or 80 deg. min 1A one
MANOJ
File Type: pdf 250_Thermal_Switch_Product_Brochure.pdf (90.5 KB, 706 views)
Old 9th November 2012, 11:21 AM   #2813
hi hadi,
MANOJ
Hi my good friend
thanks for your reaply but i dont know hove can i use that
i mean hove can control amp with this thermal switch
were i must conect it?
in input section for cut input signal?
i am wating for your power full DC 2 DC converter
thanks so much
Old 9th November 2012, 12:22 PM   #2814
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Manojtm
greetings why 1AMPERE if 12 volt operated dc protector is used the positive 12 volt should be in series with the thermal switch going to dc protector relay when thermal switch activates at 75deg power to relay is cut off and amp shuts down as the temprature reduces relay will be energised
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 9th November 2012, 01:05 PM   #2815
CPX is offline CPX  Romania
manojtm ,what chip do you use for dts/ac3 digital input?To my knowledge there is none available for public due to copyright law.
Old 9th November 2012, 04:13 PM   #2816
Hi cpx
how are you friend?
i am hapy to see you again
Old 9th November 2012, 04:18 PM   #2817
Not very well unfortunately, but i am trying to keep going...thanks a lot for asking
Old 9th November 2012, 04:22 PM   #2818
kirubakaran is offline kirubakaran  India
Default hi hadig
Originally Posted by Hadighorbani View Post
HI my friend
i dont use pereamp or crosse over. i just use PT2322 tone control for 5 chanel amp. what you say? is it enoufe to me or i must use pereamp?
i build it for my own car in home
do you have beter IC like 6 chanell controlabel ecolayser like pioneer car player? it must control by micro controler
can you offer to me a beter IC?
my car player dont have digital exit and i can not use it beacuse i dont have any knowleg about digital sound
sorry for my bad english friends
thanks to all
have a nice day
hi hadigho,
greetings,
use thermal diode to sense temp with microprocessor. if sence over temp. send command to mute all channel.
Old 9th November 2012, 04:45 PM   #2819
thanks
i am useing LM35 for invironment temp and show in lcd and first time turn on fans and in second time turn off the swiching board.
every chanels have owen thermal control
i want to turn of and on chanel by chanel with every owen amp temp sensor not by micro
i dont want turn off all divaces beacuse sub amp is hot
thanks for your helping and sorry for my english
have nice time for all and cpx
Old 9th November 2012, 04:50 PM   #2820
Default hi hadig,
if you want individual thermal protection, use apex protection schematic.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
