ucd 25 watts to 1200 watts using 2 mosfets - Page 280 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 6th November 2012, 03:35 PM   #2791
Default thanks to andrewlebon
Originally Posted by andrewlebon View Post
new smps by detex
Hi sir andrewlebom
please share every thing you have for new smps by detex
thanks
Old 6th November 2012, 07:27 PM   #2792
stewin is offline stewin  Kenya
hi andrew even fredos uses toroid core for his hi power D-amp over 7kwts
but in switching he uses igbt and not fets
Old 7th November 2012, 05:04 AM   #2793
guys please share a good and hi power smps that can be handel the class d amp
please do it for all peopel in this topic
thanks
good boy stewin
Old 7th November 2012, 05:05 AM   #2794
sir manojtem
i am waiting for your answer sir
have nice time all off you
Old 7th November 2012, 06:30 AM   #2795
manojtm is offline manojtm  India
manojtm's Avatar
Hi sir manojtm
what is the bias port on your AUD600 amp?
how can i brighe 2 of them?
can i use AUD600 amp with + - 30VDC and how much power can handel with this voltage?
sorry for my bad english
thanks
sir manojtem
Hi Hadi,
ask about the 12v Bias point ??
you should assemble both PCB do not treat separate.
you can bridge my AMP AUD600 i will give you schema and wiring diagram
+30v -30v supply you will get 100W @4 Ohm load
for all DIY s
200V MOSFET like IRFP250N can handle max. +125v -125V supply with respect to GND and it will not survive short circuit and over current, it can handle only 8 Ohm load(tested OK). 200/1.414 -15 = 126 if it is wrong don't fire me!!!!!!
MANOJ
Old 7th November 2012, 08:49 AM   #2796
manojtm's Avatar
Hi Hadi,
AUD600 schematic i will send to you soon pls wait
MANOJ
Old 7th November 2012, 09:17 AM   #2797
Default thanks to manoj
Originally Posted by manojtm View Post
Hi Hadi,
for all DIY s
MANOJ
Hi sir manoj
i mean balance not bias
sorry
how many voltage and curent for 300watt in 2 ohm load?
i will creat both of power and amp board
i have this and it is diferent with your last PDF file.
please help me to do that
sorry beacuse i am basic in electronic but i love it.
thanks friend
http://img4up.com/up2/21712604660202759918.jpg
Old 7th November 2012, 09:28 AM   #2798
manojtm's Avatar
Hi hadi,
for BAL INPUT + & - is input if you are connecting UN BAL mode + join to GND
for 300W @ 2 Ohm load you need +37V - 37V Supply @10A min.
MANOJ
Old 7th November 2012, 09:33 AM   #2799
Hi Hadi,
MANOJ
thanks dear friend
thanks for your replay
what is this two point?
one is GND?
http://img4up.com/up2/79759157898187468456.jpg
Old 7th November 2012, 09:37 AM   #2800
Hi hadi,
MANOJ
i do not underestand what are you say.
please say it more clear
thanks
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
