ucd 25 watts to 1200 watts using 2 mosfets
Old 4th November 2012, 03:26 AM   #2781
NANOTECNOLOGIA is offline NANOTECNOLOGIA  Brazil
Originally Posted by andrewlebon View Post
Hi Nano
greetings any idea of core used in smps the round one with yellow tape and what core material please can you help out
warm regards
andrew
I try MMT140T5020
:: Magmattec - Tecnologia em Materiais Magnéticos
Nano.
Old 5th November 2012, 06:24 AM   #2782
stewin is offline stewin  Kenya
Originally Posted by fra View Post
If anyone wants to test the modified IRSK4.5 board(#2731) in the board-12x TO220
Warning board has not yet tested!
what about the component side?
Old 5th November 2012, 10:50 AM   #2783
fra is offline fra  Slovenia
component side is same as this only instead of 3 pairs irfp90n20 is 6 pairs mosfets in housing TO220
File Type: jpg Amplificador Classe-D pg 74 components irs4k5.jpg (451.5 KB, 1621 views)
Old 5th November 2012, 11:41 AM   #2784
thanks fra .
do you have the lay file with components?
Old 5th November 2012, 04:46 PM   #2785
Hadighorbani is offline Hadighorbani  Iran
hi to all
this topice i meny usefull
thanks to all
have nice time
Old 5th November 2012, 06:57 PM   #2786
This is all I got.
Old 6th November 2012, 02:22 AM   #2787
kirubakaran is offline kirubakaran  India
Default pls post 3 pair 90n20 lay out file
hi fra,
greeting.
pls post 3 pair 90n20 layout file, thank you.
Old 6th November 2012, 04:50 AM   #2788
On page 272 - #2712
Old 6th November 2012, 09:36 AM   #2789
Hi sir manojtm
what is the bias port on your AUD600 amp?
how can i brighe 2 of them?
can i use AUD600 amp with + - 30VDC and how much power can handel with this voltage?
sorry for my bad english
thanks
Old 6th November 2012, 10:44 AM   #2790
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default ROUND TRAFO
new smps by detex
"It's Better to try and fail than to never know and always wonder"
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
