ucd 25 watts to 1200 watts using 2 mosfets
Old 1st November 2012, 01:05 PM   #2771
kirubakaran is offline kirubakaran  India
Default pls give the programmer schemenatic
Originally Posted by irvynejay View Post
here more updated LC meter i also made and it works well
small 100uh coil can be found on defective tv or psu
hi, greetings,
first fo all thank you for share the lc meter share schemantic i am intrested in, i search internet about pic programmer but lot of schemantic so i confused. pls share the programmer schemantic.
Old 1st November 2012, 02:19 PM   #2772
sathit dokmadue is offline sathit dokmadue  Thailand
thank you very much
Old 1st November 2012, 02:51 PM   #2773
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
use simple pic programmer posted by stewin post #2734 or
HamRadioIndia • Multi PIC Programmer
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 2nd November 2012, 08:48 AM   #2774
Hadighorbani is offline Hadighorbani  Iran
Default thanks to manojtm
Originally Posted by manojtm View Post
Hi Hadighorbani,
Ok i will do this is the clear pdf (1:1)file with some part modified you can use this
MANOJ
very thanks for pdf friend
Old 2nd November 2012, 01:04 PM   #2775
hi again mr manojtm
can you please share part list of your amp and swichin power?
it is important beacuse i do not know which of resistor are 1% for example and some of part is unknown to me.
very thanks friend
Old 3rd November 2012, 06:31 AM   #2776
manojtm is offline manojtm  India
manojtm's Avatar
hi again mr manojtm
very thanks friend
Hi Hadi,
all resistors are 5% except ** one (1K 1%) you can vary the value ex: 1K or 820 Ohm or 680 Ohm or 560 Ohm or 470 Ohm. lower the value will increase the fsw. NB:keep in mind your MOSFET(low switch ON,100nC and high speed switch) will support the high fsw.
LC value also vary when you change the fsw ex: 500 Ohm resistor L&C will be 33uH & 0.47uF/250v (fsw = @400KHz)
IR2110 pin 5 & 6 connected capacitor is 1uF/100V.(type mistake 10u/100v)
and snubber 47 ohm 0.5W with 100pF/1kv,MUR1560 & 25uH coil is an optional ( it is for EMI reducing)
MANOJ
Old 3rd November 2012, 12:21 PM   #2777
Hi Hadi,
MANOJ
thanks
and ETD29 have gape or not?
Old 3rd November 2012, 03:46 PM   #2778
Maxmud is offline Maxmud
Hi irvynejay
Please send pcb bridge amplifier that in hte picture
me email: as.rebachuck@gmail.com
Old 3rd November 2012, 09:02 PM   #2779
fra is online now fra  Slovenia
If anyone wants to test the modified IRSK4.5 board(#2731) in the board-12x TO220
Warning board has not yet tested!
Old 4th November 2012, 01:16 AM   #2780
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Thumbs up pic of round core used 5KW SMPS
Hi Nano
greetings any idea of core used in smps the round one with yellow tape and what core material please can you help out
warm regards
andrew
File Type: jpg 375619_366626093408340_1869651388_n.jpg (112.7 KB, 1730 views)
"It's Better to try and fail than to never know and always wonder"
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
