ucd 25 watts to 1200 watts using 2 mosfets - Page 277 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 29th October 2012, 02:17 PM   #2761
stewin is offline stewin  Kenya
use t-106 26 yellow core with white strip from old computer power supply.
coil
>>>> 30 turns of 16awg wire length of wire 1.1mtrs
Old 30th October 2012, 03:10 PM   #2762
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
why you need 16awg wire for lc meter? 82uH coil you can purchased from electronic shop it is ready available.
regards
MANOJ
Old 30th October 2012, 04:08 PM   #2763
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
Default LC meter
here more updated LC meter i also made and it works well
small 100uh coil can be found on defective tv or psu
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 30th October 2012, 08:31 PM   #2764
cool . thanks irvynejay for sharing
Old 31st October 2012, 03:46 PM   #2765
andrewlebon's Avatar
Default CIRCUIT OF SMPS WITH MODIFICATIONS
new detex smps layout
"It's Better to try and fail than to never know and always wonder"
Old 31st October 2012, 04:39 PM   #2766
pergo is offline pergo  Italy
pergo's Avatar
i made this driver board for UcD style class D.
It uses LT1016 for comparator, MPSW92 for level shifter, and IR2010/2110 gate driver.
ps: in the image I need to mount the feedback network and the +-5V regulators for the LT1016.
Old 1st November 2012, 07:37 AM   #2767
manojtm's Avatar
hi mr manojtm
can you share more clear and beager files for pcb and shematic off AUD600 please?
thanks
Hi Hadighorbani,
Ok i will do this is the clear pdf (1:1)file with some part modified you can use this
MANOJ
Old 1st November 2012, 09:51 AM   #2768
thanks manoj finally you've shared.
hi guys, i have these cores i think they're E65/62 cores can they work with a IGBT30n60d to produce over 5kw power? I found them in an old ups as inductors.
please help.
Old 1st November 2012, 10:09 AM   #2769
manojtm's Avatar
Hi stewin,
thanks stewin
IRFP4668Pbf worked with fsw=250KHz resistor = 10 Ohm but THD is High %
REGARDS
MANOJ
Old 1st November 2012, 01:00 PM   #2770
manojtm's Avatar
Hi all
work very good IRFP4668 resistor = 4.7 Ohm or 8.9 Ohm (parallel 10 + 82 ohm)
regards
MANOJ
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 91 16th December 2016 04:56 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
