ucd 25 watts to 1200 watts using 2 mosfets
Old 25th October 2012, 07:20 AM   #2721
stewin is offline stewin  Kenya
Originally Posted by manojtm View Post
Hi stewin,
for class d filter use ETD29 core with 1mm air gap( supply +75v -75v)
MANOJ
thanks manoj how many turns for 35uh ??
guyz the clear pdf artwork for the 4K5 have fun with real tested high power class d
File Type: pdf Amplificador Classe-D pg 74 4K5 trabalho.pdf (20.2 KB, 1354 views)
Old 25th October 2012, 08:24 AM   #2722
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
An ETD29 core with a 1mm gap in the centre leg only will have an inductance factor (Al) of close to 125nH.
The equation for the total inductance (where N is the number of turns) is N^2 * Al.
So 17 turns will give you roughly 35uH.
If you are adding a 1mm gap to an ungapped core set (so the gap is in all legs), the Al will be much lower of course.
Old 25th October 2012, 12:29 PM   #2723
thanks ouroboros
so gap in all legs it will come to how many turns to make 35uh
Old 25th October 2012, 12:57 PM   #2724
Ouroboros's Avatar
It is not a parameter that is defined in the data for the cores. This is the time to buy a low cost inductance meter perhaps?
When I get an unknown core, I wind a known number of turns on, measure the inductance and then determine Al. I then can use this value to calculate the mumber of turns needed for any required inductance on that particular core.
Old 25th October 2012, 01:01 PM   #2725
jcoelhogsia is offline jcoelhogsia  Brazil
jcoelhogsia's Avatar
ucd 25 watts to 1200 watts using 2 mosfets[/IMG]
Old 25th October 2012, 02:52 PM   #2726
ravpreet420 is offline ravpreet420
irs 3000 coil inductance(uh) ?
Old 25th October 2012, 03:02 PM   #2727
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
i used 40T .85mm core 1mm gap all (@70uH) fsw=250KHz cap=2.5uF/250V, cool quite
MOSFET IRFP250N with resistor 39 Ohm.
MANOJ
Old 25th October 2012, 03:36 PM   #2728
manojtm's Avatar
Hi stewin,
use 28T for 35uH
regards
MANOJ
Old 25th October 2012, 04:58 PM   #2729
Hi stewin,
MANOJ
what voltage? and speaker impedance? did you drive hard?
thanks for reply
Old 25th October 2012, 07:07 PM   #2730
the component side side of pcb
thanks to ht forum
Amplificador Classe-D - Página 74
have all the fun with high power amps
" seek and you shall find "
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
