ucd 25 watts to 1200 watts using 2 mosfets
Old 24th October 2012, 08:37 AM   #2711
stewin is offline stewin  Kenya
4k5 guys
hi guys here is the best i could come up with . i hope the author can post the original schema and detailed pcb files but it works.
AMPLIFICADOR DIGITAL IRS 4K5 - YouTube
Old 24th October 2012, 05:46 PM   #2712
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Stewin
greetings YES it works the pcb with bd139 bd140 is of ht forums thats why no pcb files if you are planning 3 pair fet amp CORE IS VITAL dont try gapped core wont work at high volume core saturation personally i would go for zetex trs in totem maybe this week i finish pcb protection included but totem would be smd devices
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 24th October 2012, 06:34 PM   #2713
thanks michelle but i have no option but to use etd cores.
Old 24th October 2012, 07:04 PM   #2714
don2007ksa is offline don2007ksa  Philippines
Hello Michelle and Stewin will this type of ee core will work?i'll removed this from an smps,cannot identify it.
Old 24th October 2012, 07:50 PM   #2715
Pafi is offline Pafi  Hungary
As what? Push-pull transformer? No. Output filter? Yes. Air-gap!
Old 24th October 2012, 08:24 PM   #2716
thanks pafi for answering. why can,t it work in smps?
Old 25th October 2012, 05:40 AM   #2717
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
for class d filter use ETD29 core with 1mm air gap( supply +75v -75v)
PAFI,
are you recommended this core???
MANOJ
Old 25th October 2012, 05:46 AM   #2718
manojtm's Avatar
Hi ALL
I am not recommending for MOSFET Paralleled configuration(x3 or above) use with recommended supply voltage with bridge configuration.
MANOJ
Old 25th October 2012, 06:39 AM   #2719
Hi Pafi i'm going to use this for IRS3000 (output inductor) is it possible?thank's
Old 25th October 2012, 07:03 AM   #2720
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
It depends on the type of SMPS. Push-pull, half-bridge and full bridge dc-dc converters require an ungapped core, whereas a flyback type requires a gapped core.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
