ucd 25 watts to 1200 watts using 2 mosfets
Old 21st October 2012, 10:43 AM   #2691
pergo is offline pergo  Italy
pergo's Avatar
seems this: http://www.tauscher-transformatoren..../pdf/hf_63.pdf
Rated 1.2kVA @100kHz in push pull mode.
Old 21st October 2012, 10:48 AM   #2692
Pafi is offline Pafi  Hungary
99 % of the members here will never use the amplifier for a long time at more than 30 % of the rated power. So thermally it can be designed to much lower power. This means lower size transformator. But everybody have to make this decision on his own.
Old 21st October 2012, 11:09 AM   #2693
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
THANX pergo is it suitable for half bridge smps? example ir2110 with SG ic?
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 21st October 2012, 11:29 AM   #2694
pergo's Avatar
yes, half bridge is a kind of push-pull
Old 21st October 2012, 11:49 AM   #2695
irvynejay's Avatar
THANK YOU
Old 22nd October 2012, 06:11 AM   #2696
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
managed to make them stable enough that i've decided to case them up and use them as the resident sub amp.
the output inductor goes too hot after 2 hours of movie run with huge bass so i've added an 80mm fan blowing to the pcb. gonna find another fan and do a permanent installation. the output mosfets are mounted to a heatsink underneath the pcb. the blue pcb on the top right is a 2x4 balanced minidsp to provide all the necessary dsp processing to the amp.
they're quad channel irs900d bridged into 2 channel powering a 4 ohm sub. switching frequency are reduced to 250khz, output inductor are made from T106-2 iron toroid with 21uh inductance. output mosfet are irfb5615.
each of the bridged channel powers one of these 15" diy sub:
in room frequency response of the subs powered by the amp:
stopped at 102db before i could see any compression limit on the sub. don't wanna break the house.
Old 22nd October 2012, 06:18 AM   #2697
stewin is offline stewin  Kenya
cool work paskal what voltage are you using ? and the amp channels are in bridgemode? do the outputs heat
Originally Posted by stewin View Post
hi andrew pls post the pcb files of the irs3000d the one using bd 139 and 140 as buffers gate drivers
thanking you in advance stewin
hi michelle
the pcb files or the schematic please
Old 22nd October 2012, 06:27 AM   #2698
JLesterP is online now JLesterP  Philippines
Hi Paskal,
What rail voltages did you use?
Old 22nd October 2012, 07:55 AM   #2699
paskal9's Avatar
Originally Posted by jlester87 View Post
Hi Paskal,
i measured 52V-0-52V after rectification and caps bank. the toroid is 35-0-35 500VA.
for those of you guys that are considering about paralleling the output mosfet, i really don't think it's necessary. well unless you're gonna be driving them into 1 ohm. i'm only using irfb5615 rated at max 35A current and they have absolutely no problem into 2 ohm. they don't even heat up driving my subs at said volume.
and for what it's worth, more power are used to drive low frequency <80Hz compared to higher frequency. i really think a single pair of a relatively good mosfet stuck to a heatsink is enough. but that's just me.
to reduce the mosfet and ir2110 heat output to a minimum i've settle at 250khz switching frequency with 27 ohm gate resistor. i know some might argue that much gate resistance will increase thd but i found that higher gate resistor have no immediate effect to the sound quality of the sub.
higher gate resistor reduced the mosfet heat output to a bare minimum, reduced the idle current draw by about 20% (if i remember correctly) and reduced the ir2110 heat output considerably with no loss of sound quality that i can hear of. not scientific as i didn't exactly measure the SQ but changing back and forth between the 2 pcb i think i even prefer the pcb with 27 ohm gate resistor. maybe i'm bias but i still prefer minimum heat output compared to lower thd.
Old 23rd October 2012, 03:57 AM   #2700
What's the size of your inductor? Is it T106 or T130?
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
