| Class D Switching Power Amplifiers and Power D/A conversion |
#2681 |
#2682 | |
i,ll have to use ee cores from smps power supply with piece of cd to make 1mm gap, until i get my hands on the red or black toroid core.![]()
#2683 | |
thanks regard |
#2684 |
hi andrew pls post the pcb files of the irs3000d the one using bd 139 and 140 as buffers gate drivers
thanking you in advance stewin |
#2685 | |
don't know if produce that power. Yamaha says 750x2 @4ohm, so you've to generate something like 2kW. The IGBT doesn't make the power, but the transformer design. 2 IGBT are ok for that power, they can handle 55A each! At 220Vac side, 55A is a huge current. IRG4PC50U, according to datasheet, are "optimized" up to 40kHz in hard switching but you can use them at 100kHz if you design well the driver circuit, transformer, deadtime, etc.. IRFP460 are less current, bit faster, but obsolete. IRG4PC50U are good for a <100kHz smps, like an half-bridge design. |
#2686 | |
http://www.irf.com/product-info/data.../irg4pc50u.pdf See Fig. 1 - Typical Load Current vs. Frequency ! The curve drawn with _.._.._ 16A @ 40 kHz and 10 A @ 100 kHz. Transformer, dead time and other things are not specified. They supposed to be well designed. Nobody specify their product for using in badly designed environment, so no overdrive can be recommended just because "you design it well". For limited time higher current can be allowed though, esecially if (while) heat sink is cold. For efficiency calculations you must consider switching loss. Switching loss is 0.5-2 mJ (details in datasheet). For examle at 100 kHz 1 mJ is 100 W. |
#2687 |
Thanks Pergo, I will try to incorporate those IGBT with the below design to get at least 2.5 KW. I will use 85KHZ.
Do you have a link to show/guide how to coil/design IGBT transformer. Thanks Pafi, so if I use 30KHZ I will have the freedom to go up to 40 Amps at +/- 85V? Am a bit illiterate with calculations, please forgive my many questions. And may the Almighty GOD JEHOVAH bless you all for your replies. Last edited by stewin; 20th October 2012 at 09:39 AM. |
#2688 |
for a 2.5kW you need a huge transformer, something like PM74 (http://www.tauscher-transformatoren..../pdf/hf_64.pdf) or two ETD59 if you switch below 100kHz.
#2689 |
thanks pergo now i understand if i decide to go with low frequency, i will have to hustle for a complex transformer etd42-54 can't help.
thanks again |
#2690 | |
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend |
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
