ucd 25 watts to 1200 watts using 2 mosfets
Old 10th October 2012, 12:07 AM   #2641
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default HELLO
Hi Kirubakaran
greetings before you attempt making d class amps get a proper core T157-2 OR SIMILAR MATERIAL 2 CORE irs 900 amp i feel very sensitive if proper core is not used try the irs 3000 pcb its working good
has ocp will save your mosfets detex audio has changed pcb layout with a reason DONT try IRS2092 till you have made a few dclass amps its cost in india is about400 rs
warm regards
andrew lebon DONT TRY OTHER CORES
"It's Better to try and fail than to never know and always wonder"
Old 10th October 2012, 07:32 AM   #2642
kirubakaran is offline kirubakaran  India
Originally Posted by andrewlebon View Post
Hi Kirubakaran
warm regards
pls post irs3000 pcb layout.
Old 10th October 2012, 09:21 AM   #2643
don2007ksa is offline don2007ksa  Philippines
Default IRS DUAL OUTPUT pdf
RNS,please check
Old 10th October 2012, 09:25 AM   #2644
pcb of irs 3000 is on post 2602 component placement same as irs 1500
Old 10th October 2012, 11:24 AM   #2645
JLesterP is offline JLesterP  Philippines
Which toroid is better for class D amps? Sendust core or iron power type 2?
Old 10th October 2012, 02:37 PM   #2646
Default IRS3000D
RNS CHECK PLS.
File Type: jpg modelo final 09 09 2012 (1)IRS3000 D.jpg (184.1 KB, 2393 views)
Old 12th October 2012, 09:28 AM   #2647
stewin is offline stewin  Kenya
[QUOTE=manojtm;3190860][QUOTE]hi i will make the amp i am interested for the one with irfp250 +/-80vlts switching at 250KHz
Hi stewin,
with limitter or without limitter which one you ask and PCB not compleated
REGARDS
MANOJ
without limiter but with overcurrent protection if possible . you can add totem pole so i can use 3 pairs irfp260n
Old 12th October 2012, 10:08 AM   #2648
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
One question..
Is it safe to use 200v Vds (like IRFP250) MOSFETs with +/-100v supplies in this circuit (the first 1250W into 4R one)..
Best regards,
Ozgur
Old 13th October 2012, 12:42 AM   #2649
Default IRS 3000 D
Hello
greetings IRS3000D with bd139 140 3 pairs FDA90N20
warm regards
andrew lebon
Old 15th October 2012, 04:48 AM   #2650
I integrated the OCP in the bias regulator for IRS900
You just need to put a shunt resistor in the low side of IRS900 and cut the "SD to ground" track in IR2110 IC.
Then connect the "pad-sense" pin between the shunt resistor and lowside mosfet.
Connect the "pad-prot" to SD pin of IR2110.
The OCP is based on IRS2000.
LM311 outputs "low" if overcurrent is detected, then triggers the NE555 to output "high" to the SD pin of IR2110 for n seconds.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
