ucd 25 watts to 1200 watts using 2 mosfets
Old 8th October 2012, 09:03 PM   #2631
exflaco is offline exflaco  Armenia
Could share original Sprint Layout files,tanks
Old 9th October 2012, 11:21 AM   #2632
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
Originally Posted by kirubakaran View Post
Hi.. pls help to fix the problem i will try irs900 and amplificador 1200 schematic with irfp250 ir2110 get warm and smoke logic supply 5v rail voltage +-60 V pls guide me to how fix this problem
which design that you're using? irs900 or amplificador 1200?
if this if your first project, it would be best if you could try with a lower, say 35 or 45v first before moving to >50v. my amp which is dead stable at 35v went up in smoke when i feed it 65v. make a stable amp at lower voltage first before going higher.
Old 9th October 2012, 12:06 PM   #2633
kirubakaran is offline kirubakaran  India
Question i will try both desing problem same
i will try both desing, problem are same. +/- 30v amp ok. but i feed above 40v gate driver get warm or smoke. pls help to solve.
Old 9th October 2012, 02:42 PM   #2634
Default iraudio class d amp model with ir2011
iraudio amp class d amp model with ir2011 found on internet. ir2011 is not available in my location can i change ir2011 to ir2110 any difference between gate driver?
Old 9th October 2012, 03:21 PM   #2635
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Kirubakaran
greetings what core are you using
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 9th October 2012, 03:30 PM   #2636
manojtm is offline manojtm  India
manojtm's Avatar
Hi andrew,
EDT29 with 1mm Gap (70uH) coil was tested, Better sound compare to my Drum core
only EMI is little high compare to Drum Core,cool
regards
MANOJ
Old 9th October 2012, 05:48 PM   #2637
don2007ksa is offline don2007ksa  Philippines
Default IRS DUAL OUTPUT
hello kirubakaran,IR2110 is a 14pin package while IR2011 is an 8pin you cannot insert it write away with out interchanging the pin's,one more thing it will take your time,try this layout i'll try to upload,hope it will help.
Old 9th October 2012, 06:07 PM   #2638
Originally Posted by andrewlebon View Post
Hi Kirubakaran
warm regards
andrew lebon
Hi... andrewlebon greetings i use iron ferrite t130/6 yellow ring core 22uh
Old 9th October 2012, 06:24 PM   #2639
hi... don thank you. are you try this?
Old 9th October 2012, 08:00 PM   #2640
Hi... andrewlebon
irs2092 is available in india if available what is cost each in indian currency? pls give me details thanks in advance.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
