ucd 25 watts to 1200 watts using 2 mosfets
Old 30th September 2012, 03:50 PM   #2591
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default IRS3000
irs3000 TESTED
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 30th September 2012, 04:10 PM   #2592
Hello Pafi
greetings is this ok core KS157060 please advice me suitable better core
warm regards
andrew lebon
Old 30th September 2012, 04:23 PM   #2593
AP2 is offline AP2  Italy
Banned
Please, tell me what is vcc rail,out caps value (filter to gnd), freq of carrier?
Old 30th September 2012, 05:02 PM   #2594
Pafi is offline Pafi  Hungary
Originally Posted by andrewlebon View Post
Hello Pafi
warm regards
andrew lebon
I have no idea what does that part number cover.
I prefer multi-gapped ferrite toroids, and gapped ferrite pot (or RM) cores with litz wire.
I copy what I answered to you in PM:
"There are a huge number of usable solutions, but I have no idea which is achievable for you, and which is the "best" for you. There are many optimisation target, like price, size, weight, idle loss, full load loss, EMI, etc... There is no such thing as "Best", because it depends on your preferences! This is why you find different cores in different products."
For example if you choose very low permeability, then idle loss can be very low, but full load loss will be higher. You have to decide which is more important for you!
There are general rules, but they never say what is the best, they say "if you do this, you will get that". If you want to know, you have to ask about basics, not the solution!
Old 30th September 2012, 05:09 PM   #2595
วงจรคุณถาพสูงจาก Detex Audio
ใช้ไฟเลี้ยงวงจร +/-50V ถึง +/-130V
ทำงานที่ความถี่ 250kHz
ตอบสนองความถี่ 20Hz - 20000Hz
กำลังขับ 1000+1000 W @8 Ohms
กำลังขับ 1500+1500 W @4 Ohms
กำลังขับ 3000+3000 W @2 Ohms ( ใช้ไฟเลี้ยงวงจร +/-130V )
มีวงจรป้องกันสายลำโพงช๊อต
ขนาดของบอร์ด กxยxส 75mm x 295mm x 70mm
Old 30th September 2012, 05:12 PM   #2596
Hi AP2
greetings these are the specifications of this amp filter cap to ground is .47 450 volts the green one
warm regards
andrew lebon
Old 30th September 2012, 05:14 PM   #2597
Hi Pafi
greetings many many thanks for replying i am new to dclass just make these amps for fun thanks for sharing your knowledge
warm regards
andrew
Old 30th September 2012, 05:19 PM   #2598
Default detex audio IRS3000
cs27075 core used 2 cores parallel
warm regards
andrew lebon
Old 30th September 2012, 06:34 PM   #2599
NANOTECNOLOGIA is offline NANOTECNOLOGIA  Brazil
irs3000 TESTED
warm regards
andrew lebon
send this to me pcb
Nano.
Old 3rd October 2012, 11:34 PM   #2600
Thank andrewlebon I can help with anything just say.
Nano
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
