ucd 25 watts to 1200 watts using 2 mosfets - Page 259 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th September 2012, 03:53 AM   #2581
hello, fra it's on page 254 you can print it on A4 size 1:1 ratio.
Old 26th September 2012, 12:42 PM   #2582
andrewlebon's Avatar
Default ULTIMATE CORE
Micrometals Arnold Powder Cores
Hello
greetings just want some knowledge on cores used in dclass amps
1 Optilloy optimised alloy powder
2 Super MSS
3 Mollypermalloy powder cores
4 Sendust kool mu cores
5 Iron powder cores
which is the best core from the five following materials secondly does more
permeability make the core better i ask this because everyone is using
iron powder core but DETEX audio uses sendust material core in all his d class
amp kits and lastly what core do proffessional d class amps use in high power amps hoping someone can enlighten me and all
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 29th September 2012, 03:04 AM   #2583
Hi jlester87
greetings the IRS1500 pcb has ocp on board it works makes no sense attaching another pcb i have almost finished irs 3000 pcb will upload working amp pics
TRY IT
warm regards
andrew lebon
Old 30th September 2012, 11:08 AM   #2584
I have this green toroid, but has unusually high value of inductance, in the picture it only takes one turn to make a 64uH value, 4 turns in this toroid has a value of 500uH!
Can I use this with any class D amp?
I have another yellow toroid from computer smps, I'll just make a gap to make it usable.
Old 30th September 2012, 11:39 AM   #2585
Banned
You cannot use any of those two, they are simply the wrong type.
You need a T106-2 from micrometals or similar for class d output.
Old 30th September 2012, 12:26 PM   #2586
Is T184-2 enough for 1kw power?
Old 30th September 2012, 12:30 PM   #2587
Pafi is offline Pafi  Hungary
On the picture I see 2 turns and 2 cores together. Al=64000nH/2/4=8000 nH/turns^2 It's ferrite. If you can break it into 4 symmetrical quarters, and insert 4*0.4 mm air gap, it can be a good core for output inductor.
Yellow toroid is very bad, gapping makes it somewhat better, but not good.
Old 30th September 2012, 12:31 PM   #2588
hello
greetings can anyone please reply to post 2582 for best core IRS3000 IS WORKING
is iron powder or sendust material core better
warm regards
andrew lebon
Old 30th September 2012, 12:32 PM   #2589
Much more then enough! Up to about 4 kW.
Old 30th September 2012, 12:54 PM   #2590
Originally Posted by andrewlebon View Post
hello
warm regards
andrew lebon
Optimal material and permeability is a very long procedure to analyse.
Especially if there is no optimisation target specified.
I can tell only 1 thing: that iron powder on your link (840 mW/ccm, mu=75) is not good enough, but there are many other options.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
