ucd 25 watts to 1200 watts using 2 mosfets
Old 25th September 2012, 05:05 AM   #2571
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
900 watts with IRFB4227 or mosfet FDA90N20
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 25th September 2012, 11:25 AM   #2572
exflaco is offline exflaco  Armenia
Jlester IRS900 use irfp264
Old 25th September 2012, 11:54 AM   #2573
kirubakaran is offline kirubakaran  India
hi to all,
help me to design class d amp 500w using ir2110 i will try last few months many time its will fail. will try irs900 but is get warm in ir2110 so pls give any suggestion to make success full class d amp or give no error class d amp schematic.
Old 25th September 2012, 11:55 AM   #2574
Default pls help me
hi to all,
help me to design class d amp 500w using ir2110 i will try to many time its will fail. will try irs900 but is get warm in ir2110 so pls give any suggestion to make success full class d amp or give no error class d amp schematic.
Old 25th September 2012, 12:17 PM   #2575
Kirubakaran Irs 900 better choice for you minus +-v rail (60-70v)obtain minus power may by 500w IRS500 its the same Irs900
Old 25th September 2012, 01:20 PM   #2576
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
the design is stable with other mosfets. i've tried it with irf540n and irfb5615 and they're both stable.
Originally Posted by kirubakaran View Post
hi to all,
do try the irs900d. you could just use 1n4148 for all the diodes except for the bootstrap diode nearest to the ir2110. 1n4148 should be easily available locally to most people. use 27-30 ohm gate resistor and you should reduce the mosfet and ir2110 heat.
also it makes much sense to run two of the irs900d bridged if you're thinking of drawing high power from them.
Old 25th September 2012, 02:01 PM   #2577
CPX is offline CPX  Romania
Increasing gate resistors to 30 ohms is not a good ideea, it will increase deadtime and quiescent current.
Old 25th September 2012, 06:55 PM   #2578
fra is offline fra  Slovenia
Originally Posted by don2007ksa View Post
waiting some part's almost done.
hey can you share your board?
Old 26th September 2012, 12:11 AM   #2579
JLesterP is offline JLesterP  Philippines
Can I use IRFP260?
It is available in my place.
Old 26th September 2012, 12:18 AM   #2580
Hello
greetings anyone have IRS3000 LAY files in sprint to share
warm regards
andrew lebon
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
