ucd 25 watts to 1200 watts using 2 mosfets
Old 17th September 2012, 12:33 PM   #2541
exflaco is offline exflaco  Armenia
Don 2007ksa and the schem for correction?
Old 17th September 2012, 04:06 PM   #2542
don2007ksa is offline don2007ksa  Philippines
Hi Andrewlebon,i will try to finish it with in this week,this layout is base on IRS900 with TC4420 used as buffer to drive the high gate capacitance output transistor,i hope this will not affect the self oscillation of the circuit,better to try and stay wonder,cheer's.
Hi exflaco this is base on IRS900,but of course the inverter pin's(CD4049)is different.
Old 17th September 2012, 05:08 PM   #2543
NANOTECNOLOGIA is offline NANOTECNOLOGIA  Brazil
with TC4420 could not make it work with 2 pairs.
Nano
Old 17th September 2012, 06:33 PM   #2544
Hi nano,TC4420 is a 6A driver according to the data sheet's and i'm going to used it with only 3 output per rail,meaning two of this(TC4420) for high and low,is it not possible?please give an advice thank's.
Old 17th September 2012, 08:09 PM   #2545
I did so and it worked
Uploaded with ImageShack.us
Old 17th September 2012, 09:33 PM   #2546
Nano colud share pcb ,tanks
Old 21st September 2012, 03:40 AM   #2547
sathit dokmadue is offline sathit dokmadue  Thailand
Originally Posted by manojtm View Post
Hi CPX
here i am attaching my old class d amp test report
regards
MANOJ
Thank you very much
Old 21st September 2012, 04:04 AM   #2548
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default Nano can you please share pcb
classe d.rar - 4shared.com - online file sharing and storage - download
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 21st September 2012, 01:50 PM   #2549
sandeep kayarkar is offline sandeep kayarkar  India
Default how about this core??????
sir, i found this E E core. material........don't know, can i use it with IRS900D?
Old 21st September 2012, 05:46 PM   #2550
can use only hit inductance.
Nano.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
