ucd 25 watts to 1200 watts using 2 mosfets
Old 10th September 2012, 04:24 PM   #2511
CPX is offline CPX  Romania
Manoj:
What kind of resitive divider you have used?
Old 10th September 2012, 04:31 PM   #2512
manojtm is offline manojtm  India
manojtm's Avatar
Manoj:
CPX
i used series 4k7 ground 6k8 with 1nF (2) series 4k7 ground 4k7 with 1nF (3) series 10k ground 6k8 with 1nF (4) series 1k ground 6k8 with 1nF
today i directly connected to input with very low volume, unfortunately my sound card damaged.
MANOJ
Old 10th September 2012, 04:34 PM   #2513
For initial tests a 1/10 divider with 100 nanofarads to ground is enough.
NEVER connect directly, of course you sound card got damaged.
Also never make connectios while both amplifier and computer are on.
Old 10th September 2012, 05:50 PM   #2514
exflaco is offline exflaco  Armenia
Manojtm, schem and pcb 4all diyers please
Old 10th September 2012, 11:05 PM   #2515
bogdan91 is offline bogdan91
???? D-class 1200w.mp4 - YouTube
that is amp in the few posts upper i started him its cool but need delay for good start
Old 12th September 2012, 08:23 AM   #2516
manojtm's Avatar
Hi CPX
Today i got Yorkville schematic comparing with my circuit its all most same what i did
so i quit THD measure( save my new sound card ) if you need schema i will send you
Manoj
Old 12th September 2012, 09:36 AM   #2517
manojtm's Avatar
Hi All
Yorkville ls800 (1500W 18" Sub woofer) using lm311/555/ir2110/ir2110/IRFP31N50 +130V -130V bridge config.
regards
MANOJ
Old 12th September 2012, 10:52 AM   #2518
Default Yorkville free
http://www.yorkville.com/downloads/servman/smls801p.pdfYorkville all model free4all in the web page 145v igbt out non ucd limiter (13600)ocp
Old 12th September 2012, 01:30 PM   #2519
Manoj:
This in not a solution, THD depends on implementation not on schematics used..With correct divider and ground connections there is no danger for the sound card.
Old 12th September 2012, 02:29 PM   #2520
manojtm's Avatar
Hi exflaco
that carrier based class d using fsw=@80KHz Max. IGBT freq. is 150KHz
Manoj
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
