ucd 25 watts to 1200 watts using 2 mosfets
Old 22nd August 2012, 09:54 AM   #2401
prasanna gunasinhe is offline prasanna gunasinhe  Sri Lanka
prasanna gunasinhe's Avatar
Andrewlebon, Can you please post the schematic of DETEX 1500W PCB??
Old 22nd August 2012, 11:16 AM   #2402
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Hi Prasanna
greetings there are no schematics just make pcb put components and enjoy
the sound ONLY if you have the proper core make it otherwise
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 22nd August 2012, 11:51 AM   #2403
jcoelhogsia is offline jcoelhogsia  Brazil
jcoelhogsia's Avatar
andrewlebron, you have pcb Class D bridges.
warm greetings.
Old 22nd August 2012, 01:06 PM   #2404
Hi Jcoelhogsia
greetings no i dont have bridges pcb already d class is so powerful and
bridges only good for 8 ohms load
warm regards
andrew lebon
Old 23rd August 2012, 02:07 AM   #2405
UCD Protection against short circuit at output speaker. - YouTube
Old 23rd August 2012, 02:53 AM   #2406
CPX is offline CPX  Romania
Do you use sensing tranformer or resistor?
Do you use di/dt limiting inductor or not?
Have you tested this protection with short on output and then feeding high frequency sinusoidal signal?
Old 23rd August 2012, 07:13 AM   #2407
sandeep kayarkar is offline sandeep kayarkar  India
Default About Core
Sir, I have these core from old Computer SMPS. the size of core u can see, i wanted to know that can i use it with IRS1500D or for irs900D?
Originally Posted by andrewlebon View Post
Hi Prasanna
warm regards
andrew lebon
Old 23rd August 2012, 07:39 AM   #2408
NO these cores wont work use SENDUST material cores
Old 23rd August 2012, 08:15 AM   #2409
stewin is offline stewin  Kenya
they will certainly be hot as a soldering gun, but if you have no option, use a hack saw to cut 1mm gap which will atleast help.
the best thing is to use the EE or the EI core from that PC
>>>> coil 24turns,use a piece of old CD to make 1mm gap
refer to previous posts, there're even instructions by other DIYers on how to go about it
Old 23rd August 2012, 08:28 AM   #2410
you can incorporate the OCP protection with any UCD or non UCD class D amps
The schema and the artwork are in the links below:
diysmps
diysmps
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 10:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
