ucd 25 watts to 1200 watts using 2 mosfets
Old 21st August 2012, 03:23 PM   #2391
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default detex audio 1500 watts
detex pcb
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 21st August 2012, 03:37 PM   #2392
mosfet used is FDA69N25 from FAIRCHILD
Old 21st August 2012, 03:47 PM   #2393
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Originally Posted by andrewlebon View Post
detex pcb
warm regards
andrew lebon
FYI - It seems that some of the tracks (under the IC's) got "masked" by the white background...
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 21st August 2012, 06:54 PM   #2394
exflaco is offline exflaco  Armenia
Talking Best diyer place
Your request
Old 21st August 2012, 07:31 PM   #2395
stewin is offline stewin  Kenya
Originally Posted by manojtm View Post
HI ALL,
My new class d design it will work very cool on +80v -80v @250KHz full band
i connected 3x 8 Ohm speaker parallel without heat-sink
MANOJ
pls post a schema are the outputs irfp250?
Old 21st August 2012, 07:34 PM   #2396
dudaindc's Avatar
Originally Posted by exflaco View Post
Your request
Thanks!
Old 22nd August 2012, 05:13 AM   #2397
Default pcb 1500 watts detex audio
detex pcb
Old 22nd August 2012, 05:55 AM   #2398
hi andrew and exflaco can i use irfp250n/260n with pcb 1500 watts detex audio at +/- 75vlts dc with a 4ohms woofer
Old 22nd August 2012, 06:22 AM   #2399
yes YOU CAN USE IRF250N with 70+/- supply
Old 22nd August 2012, 06:55 AM   #2400
wow thanks. pls post schema if available can irfp260n work also at that voltage with that impedance? . thanking you in advance.
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
