Hey guys
So looks like nobody's here
I'll appriciate if anybody could help me with this amp
I manage to run this amp after a lot of mosfet failures and now the sound is kind of good but not great
I noticed that the negative rail draws way more current than positive one. when I increase the output power to about 100w, the current draws from negative rail is about 2 A while the positive one only consume 0.6 A
is this normal due to the supply of IR2110 by negitive rail?
Also I can't get a clear upper wave form in the output as you could see in the video below:
YouTube
PS: I'm using this schematic
image.png - Google Drive
Thanks in advance
your answer is in the previous posts.by those who made this amp before , please scroll way ,way upwards
Hey guys
YouTube
Thanks in advance
Simple, problem on C3 (1uf) bootstrap of ir2110 ,just replase 1uf to 10uf capacitor or add another 4.7uf
nice Work .and pcbFullbridge completed for subwoofer with protection dc /overcurrent
Finally you make it good looking amp and of course big output.
Sameer post this picture in my facebook group
congrats sir , what voltage have you used and which output fets did you use,
please share pcb files.
Good afternoon.
Can you send me the schematic for my e-mail?
luizcpimenta@gmail.com
Thank you.
Bad amplifier ....
Very bad amplifierhow to change frequency to 250Khzsuply +-50Vdc
Very bad amplifier
Hi Redmx, any suggestion best class d amplifier for this year?
hi all busy perfecting smps and ucd semi discreet .that is lm 311 and ir2110 in ucd amp. all is well the amp is o.k and cool even at 2 ohms but ocp protections are the ones holding me back .i have made lorylaci ucd version with protection ,it works well but trips very soon / early. i think when the amp is 60% loud .
i wanted it to reach about 92% at 2ohm per channel because i wanted to use full bridge +/-70vlts fets used are a pair of irfb4227 per channel any help some one??. the schematic ic below and my layouts are below.
it has been over three years and this amp is powerful but has major stability issues,
i used different layout designs and components , through hole or smd components failure is a must after long term usage .
worst failure is when you use more than 1 channel in one casing , all channels will fail and only one will remain.
with or without protection the results are the same.
any way the good side of this amp is when bridged at +/-85 volts it is insanely powerful and just warms no high heating of output fet devices a moderate sink with a small fan is more than enough .tried at 4ohms and 8ohms . but it is not stable , after working well and with good connections , it will just fail for no good reason at all.
Hi stewin,
11CH Sigma delta class D with @+/-60V rail (pioneer SC-LX901)
MANOJ
hello too sir
wow wonderful , how do they deal with interference which causes failure
i also made sigma delta which is class d 200w using tl074 . i made up to six channels with two smps Offline full-bridge SMPS....need help and had no issues . but my voltage used was +/-38 volts photos >> diysmps <<
КСТАТИ ЕСЛИ ОБРАТНАЯ СВЯЗЬ УСТАНОВЛЕНА ПОСЛЕ ДРОССЕЛЯ ЭТОЙ ПРОБЛЕМЫ НЕТ
English please.
KSTATI IF AGAIN AFTER THIS PROBLEM NO as in UcD on
By the WAY, if the FEEDBACK is SET AFTER the THROTTLE, THIS PROBLEM is NOT present (since in UCD amplifiers with a phase-leading circuit). This can be seen by giving the amplifier a rectangular signal and turn off the load.
English please.
What major problem?
Can you list all problem, maybe I can help.
Kartino
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
