ucd 25 watts to 1200 watts using 2 mosfets - Page 238 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 20th August 2012, 02:12 PM   #2371
andrewlebon's Avatar
Think its same as irs 2000d
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 20th August 2012, 03:16 PM   #2372
warm regards
andrew lebon
ok thats gr8...i'll let u know if that works or not after completing my borad
Old 20th August 2012, 04:14 PM   #2373
manojtm is offline manojtm  India
manojtm's Avatar
Hi andrew
where you get that coil, is it RM10
MANOJ
Old 20th August 2012, 04:35 PM   #2374
Hi Pafi
greetings what value for C1 nice to see your advice
warm regards
andrew lebon
Old 20th August 2012, 06:30 PM   #2375
stewin is offline stewin  Kenya
has any one tried irs amps with +/- 75 or more with a 2 ohms load successfully ? ? ? ?
Old 20th August 2012, 06:32 PM   #2376
nigelwright7557's Avatar
I run a 750 watt amp into 2 ohms with no problems.
I used a pnp/npn pair to drive the mosfet gates to get sufficient drive.
I used 4 off irfb4227 mosfets.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 20th August 2012, 06:44 PM   #2377
which schema did you use? irs2000 or ucd 25-1200??
Old 20th August 2012, 06:48 PM   #2378
I used the irs2092 datasheet circuit as the basis.
Then added gate driver transistors and 4 irfb4227.
Old 20th August 2012, 07:08 PM   #2379
is it possible for ir2110 and irfp250/260 /irfb4227 be driven comfortably at +/- 75vlts at 2ohms even if i have to use multiple with gate driver transistors?
Old 21st August 2012, 02:14 AM   #2380
Thumbs up smps supply 1200 watts
Hello
greetings 1200 WATT SMPS made by sir irvynejay its still under testing
many THANKS to SIR detex audio and nano for helping us all the way
warm regards
andrew lebon
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 91 16th December 2016 04:56 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
