Go Back   Home > Forums > Amplifiers > Class D
Old 17th August 2012, 03:46 PM   #2321
CPX is offline CPX  Romania
Something VERY bad is happening there.I didn't have this problems even on test board.Post board layout.
Old 17th August 2012, 03:53 PM   #2322
adjustments were made as said by thienchay
File Type: pdf 295130d1344427075-ucd-25-watts-1200-watts-using-2-mosfets-irs-3000d-2-_-pcb.pdf (75.3 KB, 375 views)
Old 17th August 2012, 03:56 PM   #2323
I know this board,i allready commented on it.
Distance between output transistors and buffering capacitors is huge!!,but it should work at 1 or 2 amps.You should remake it for full power.
Old 17th August 2012, 04:04 PM   #2324
i dint get u.....exactly what u wanna say,,,the capacitors on the supply rails????????
at fulll power means??????????/
Old 17th August 2012, 04:15 PM   #2325
Yes,those capacitors,they should be very close to output transistors.And ground is very bad,it has loops and and is it long and thin.You can somewhat fix this by using a ground plane on the other side conectata in 10 points butthe capacitors have to be moved.
Old 17th August 2012, 04:20 PM   #2326
can this be the cause for my problem....even with no loads...i got distorted square wave...if i would have got distorted sine wave i would have said there is ground problem...i used 33uh coil and 0.47uf cap for output filtering
Old 17th August 2012, 04:23 PM   #2327
You can somewhat fix this by using a ground plane on the other side (conectata in 10 points butthe capacitors have to be moved).
what does this means????????
Old 17th August 2012, 04:25 PM   #2328
manojtm is offline manojtm  India
manojtm's Avatar
Hi CPX
EMI 4.3mV only no problem for 2CH
see my DSO Picture
MANOJ
Old 17th August 2012, 04:28 PM   #2329
Originally Posted by manojtm View Post
Hi CPX
see my DSO Picture
MANOJ
the freq response is before output inductor or after output inductor
Old 17th August 2012, 04:32 PM   #2330
Hi CPX
see my DSO Picture
MANOJ
Where is that measured..on the supply or with the probe shorted at a certain distance?
Please post a picture of your amplifier(of both modules)
Please post your syncronizing schematic or explian how you did it.
Thanks.
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 44 3rd April 2013 02:57 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
