ucd 25 watts to 1200 watts using 2 mosfets - Page 231 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th August 2012, 11:54 AM   #2301
when i apply function generator with input frequency of 1KHZ it give output of 3KHZ ......why is that so???????????
any feedback would be highly appreciated
Old 16th August 2012, 03:55 PM   #2302
manojtm is offline manojtm  India
manojtm's Avatar
Hi ALL
Any class D amp design "high important side is level shifter" if it is not good your amp will generate noise,sparking sound etc...
all schematic shows some mistake ...........
If your design analog side voltage is 5V you should provide level shifter same and IR2110 pin 9 should be 5V. PIN 3 you can change 12V or 15V
MANOJ
Old 16th August 2012, 03:56 PM   #2303
after the 6k8 resistor on the positive side(+5.6V)in series,just cut the copper and place the resistor on it.
Old 16th August 2012, 04:00 PM   #2304
CPX is offline CPX  Romania
Originally Posted by manojtm View Post
Hi ALL
MANOJ
If level shifter is not good the amplifier will not work at all..,or something will get very hot quick.
What mistake have you found in my schematics?
Old 16th August 2012, 04:08 PM   #2305
nothing is hot....but output is distorted.....when applied input of 1KHZ it gives output of 3KHZ
Old 16th August 2012, 04:12 PM   #2306
Hi ALL
MANOJ
yes there is much noise on outputs but i dint find any source saying this voltage variations
Old 16th August 2012, 04:12 PM   #2307
Hi CPX please share your schematic,thank's a lot
Old 16th August 2012, 04:13 PM   #2308
what diff will it make...as it will be in supply???????/
Old 16th August 2012, 04:37 PM   #2309
this resistor make's the voltage to drop a few m.volt along with the current that goes to the load (TLO71) and the result's temperature,voltage stabilization.
Old 16th August 2012, 05:22 PM   #2310
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
