ucd 25 watts to 1200 watts using 2 mosfets - Page 228 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th August 2012, 06:35 AM   #2271
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
Originally Posted by sweetperfume View Post
is the resistor error only prob with this pcb or something else also...and can i replace cd4049 with 4050????
the only way of knowing is for someone with better experience with class d to etch the pcb, build and test the amp.
the irs2000/3000d pcb didn't even come with a proper schematic so probably it would be even more helpful if someone would be good enough to trace the pcb and make a schematic out of it. that would allow people with better experience to browse and check for errors as it's quite hard to check for design error just by looking at the pcb traces.
and no you cannot replace it with cd4050 as you need an inverter.
Old 15th August 2012, 06:54 AM   #2272
I have made rs900. now it has a problem. one the Mosfets isn't driven and it's working by just one of these mosfets. both of them are ok. what to do?
Old 15th August 2012, 06:57 AM   #2273
Send a message via Yahoo to ionutzxpo
• CD4049UB Inverting
• CD4050B Non-Inverting
Old 15th August 2012, 07:35 AM   #2274
then can it be used for this amp(cd4050)
Old 15th August 2012, 07:38 AM   #2275
Originally Posted by irvynejay View Post
plz dude post your schematics...need to know the reasons why i'm not getting the things worked up with my pcd
Old 15th August 2012, 07:45 AM   #2276
andrewlebon's Avatar
Default DETEX AUDIO DC PROTECT
Hi Nano
greetings i made this DETEX dc protector same one you use can you please check if its ok MPSA13 darlington transistor any substitute for it
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 15th August 2012, 09:02 AM   #2277
i had almost connected every part i guess so with irs3000d.....i would be powering it with +/-40volts.....plz give any suggestions if i would have to check out with anything serious with this pcb and schematic
Old 15th August 2012, 11:19 AM   #2278
thienchay's Avatar
No , CD4050 is Non-inverting , CD4049 is Inverting Buffer .
Old 15th August 2012, 11:22 AM   #2279
is there any substitute for cd4049 as i dont have it at my place...any perfect one with same pin out plz help me out...i need to test the design today itself...
Old 15th August 2012, 11:24 AM   #2280
irvynejay's Avatar
Send a message via Yahoo to irvynejay Send a message via Skype™ to irvynejay
i already posted i don't have schematic,, that's the only file i have i made the amp with out schematic
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 11:16 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
