ucd 25 watts to 1200 watts using 2 mosfets
Old 15th August 2012, 12:40 AM   #2261
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
IR2110 will HEAT on 2 pairs of mosfets on detex design
"It's Better to try and fail than to never know and always wonder"
Old 15th August 2012, 01:51 AM   #2262
nn20 is offline nn20
Originally Posted by irvynejay View Post
i don't have schematic i only made the amp without it and its working great
i only use detex file to make the pcb
does anyone have the correct schematic for this IRS900d?
Is this PCB correct or cointaining errors?
http://www.diyaudio.com/forums/attac...449ca921e4.jpg
I want to use IRFP250N for this AMP as it's shown in the IRS500 layout.
I wonder if irvynejay and anyone has made this AMP help me if there is some useful points.
I want to drive the Amp with -+60 volts . should i change some parameters like RSS resistors or others?
how much should it be?
please help me by your useful tips and experiences.
with Regards.
nn20
Old 15th August 2012, 01:56 AM   #2263
Hi nn20
greetings just make the pcb irvynejay posted IRP 250N works on 60 volts+/-
no change of components needed
warm regards
andrew lebon
Old 15th August 2012, 02:17 AM   #2264
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay ucd 25 watts to 1200 watts using 2 mosfets
irs900d
Irs900 - YouTube
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Old 15th August 2012, 02:17 AM   #2265
thanks to Mr lebon .and eager to read other new comments .
how much is the inductance of output inductor?
how many turns on that core( in video of irvynejay ) is needed?
i see 2 TO-220-package componnet at the bottom of PCB in that video.what are they?
Old 15th August 2012, 02:38 AM   #2266
irvynejay's Avatar
80uh ,irfb4227 ,gate r=10ohms
Old 15th August 2012, 02:49 AM   #2267
oh excuse me . I completely forget the MOSFETs which should be connected to the bottom!
80uh and 0.47uf made LPF .is it?
is it the same for IRFP250N? (amplified square waves are the same but with different domains)
Old 15th August 2012, 02:54 AM   #2268
irvynejay's Avatar
.47uf 80 uh ,irfp250n= 100 gate r
Old 15th August 2012, 04:17 AM   #2269
ionutzxpo is offline ionutzxpo  Romania
Send a message via Yahoo to ionutzxpo
ill wait for a better no errors pcb on IRS2000-3000D
Old 15th August 2012, 05:49 AM   #2270
sweetperfume is offline sweetperfume  India
Originally Posted by thienchay View Post
time recent i'm so busy , so i not yet try this PCB .
I'm temporary check , and i see R 4K7 and 1K is wrong , Detex is deceit , and i see C 100uF is not a bypass Capacitor , it connect from Ouput of TL071 to -5V6 , try swap 4K7 - 1K , and remove C 100uF .
And i 'll check it soon to find a good sch and PCB , some mistake from me , sorry .
Regards .
is the resistor error only prob with this pcb or something else also...and can i replace cd4049 with 4050????
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
