ucd 25 watts to 1200 watts using 2 mosfets - Page 226 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 14th August 2012, 09:04 PM   #2251
CPX is offline CPX  Romania
Originally Posted by sweetperfume View Post
the irs3000d dint gave up signal out from 2n5401 and the other one just blew the **** out from IR2110....cause me to lose 5 of it in a time......the frequency was a good square wave from 2n5401 in other design...but no respose from 3000d.....inspite of the frequency on the outputs there was no response from IR.....the low output of IR gave out square wave signal but the low side was still showing something and that something was a freaking "NOTHING"
i tested these designs with +/-30volts
Traces are long,ground plane is missing,ground is not thick enough,you will have problems in high curents, but it should work ok for a few wats,if it blew form the start then you made some mistake..
Old 14th August 2012, 09:12 PM   #2252
i could end up saying that i commited some mistakes but this aint the fact...i checked the design on my breadboard 100 times but there was no such mistake....the 5401 gave the clean square wave output...
Old 14th August 2012, 09:19 PM   #2253
"the 5401 gave the clean square wave output"
What do you mean by that? one transistor alone can not give any output..
Old 14th August 2012, 09:23 PM   #2254
i thought u were talking about the design with TLO74....yeah u are right i dint get any output from 5401..but at which point do u think i should check out the waveforms before installing the IR2110...and can i replace cd4049 with cd4050
Old 14th August 2012, 09:28 PM   #2255
What amplifier are you making???..you will have NO wave forms without all the parts installed and working corectly since all the amplifiers on this thread are self oscillatting ones.
Old 14th August 2012, 09:32 PM   #2256
What amplifier are you making???..you will have NO wave forms without all the parts installed and working corectly since the amplifier on this thread is a self oscillatting one.
i built one of the ir2110 model but it had lot of distortion...then i got the pcb design from thienchay of irs2000d/3000d which i tried to see whether works or not...can u tell me does that work well...and what will happen if i install all the things except output fets..to see whether the IR2110 gives the high and low output correctly??????????
Old 14th August 2012, 11:06 PM   #2257
PROTON is offline PROTON  Greece
Default wire resistor
Is there any possibility that you have used wire resistor,you might have and the have inductance so use carbon ones...just a thought...
Old 15th August 2012, 01:09 AM   #2258
abetir is offline abetir  Philippines
Originally Posted by andrewlebon View Post
green and red led used red lights up on fault
warm regards
andrew lebon
Originally Posted by exflaco View Post
Abeteer this pcb a mistake the 3,7v zener on lefth rail ,the catode mus be conect to gnd
Originally Posted by khalsa View Post
abeteer sameer x1 design I think its is true
Thank you for the feedback guys
Regards!
Old 15th August 2012, 01:26 AM   #2259
thienchay's Avatar
time recent i'm so busy , so i not yet try this PCB .
I'm temporary check , and i see R 4K7 and 1K is wrong , Detex is deceit , and i see C 100uF is not a bypass Capacitor , it connect from Ouput of TL071 to -5V6 , try swap 4K7 - 1K , and remove C 100uF .
And i 'll check it soon to find a good sch and PCB , some mistake from me , sorry .
Regards .
Old 15th August 2012, 01:27 AM   #2260
andrewlebon's Avatar
module de protection CC pour haut-parleur
LINK FOR DC PROTECT USE bc547 557 trs
"It's Better to try and fail than to never know and always wonder"
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 12:16 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
