| Class D Switching Power Amplifiers and Power D/A conversion |
#2241 |
green and red led used red lights up on fault
warm regards andrew lebon
[image] |
#2242 |
HAPPY INDEPENDENTS DAY to all indian
#2243 |
Abeteer this pcb a mistake the 3,7v zener on lefth rail ,the catode mus be conect to gnd
#2244 |
che-900e is not working ir2110 ic get hot i think ic voltage com to Vdd is 5v but this schementic is give 12v
#2245 |
#2246 | |
i tested these designs with +/-30volts Last edited by sweetperfume; 14th August 2012 at 12:07 PM. Reason: forgot to mention |
#2247 |
#2248 |
abeteer sameer x1 design I think its is true
#2249 |
sweet perfume you are very unlucky or maybe your ir2110 chip is bad or the aux voltage feeding the ir2110 has not reached 12vlts. happy independence day to all too.
#2250 |
i dint install IR2110 yet i was checking the things up that ie there everything ok...but i dont think that something ove there was ok
| Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 44 | 3rd April 2013 02:57 PM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 06:55 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
