ucd 25 watts to 1200 watts using 2 mosfets - Page 222 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th August 2012, 05:27 PM   #2211
CPX is offline CPX  Romania
Originally Posted by stewin View Post
does dead time vary with voltage ? as in the more high voltage you use the more you have to adjust dead time.? and how cn one adjust ??
Digital deadtime no,but effective analog deadtime may vary somewhat with this schematic ,you have to measure with the scope.
But with increased voltage , switching disipasion increases also , and you should adjust deadtime at maximum used voltage for lowest THD possible and maneable disipation.
Old 11th August 2012, 07:26 AM   #2212
manojtm is offline manojtm  India
manojtm's Avatar
Hi
provide fast switching diode MUR1560 like this
MANOJ
Old 11th August 2012, 04:06 PM   #2213
Originally Posted by thienchay View Post
Hi
+ (12V) on Regulator Board connect to +12V on Power board
.... and - (GND) on Regulator Board connect to COM (V-) on Power Board .
GND of Regulator must be connect to V- on Power Board .
thanks,,,Thienchay
its negative referred....i have etch the pcb of the design which u provided...can u tell me the value of the resistor RSS and osc and also RFB....i need to know the inductance of output coil
Old 12th August 2012, 03:09 AM   #2214
thienchay's Avatar
Originally Posted by sweetperfume View Post
thanks,,,Thienchay
Yeah .
- RSS dependent of rail voltage you used , you can calculate it , RSS = (Volt - V(zener) / 0,01 (set 10mA passing RSS) .
+ EX : If you used +/- 75V ; RSS = (75 - 5,6) / 0,01 = 6940 , so you should used 6,8K ohm / 2W
- RFB = 100K , OSC = 1K , it set Gain .
- OCP = (V bias x R ocp / 6800 ) / R (Source MOSFET) . Set limit of output current .
+ EX : I used 12V Bias , R ocp = 220 ohm , R (Source) = 0,02 ohm ( 5 x 0,1 ohm parallel)
(12 x 220 / 6800) / 0,02 = 19,4 Ampe
Change R ocp is change limit output current .
- L output ~ 30 - 40 uH .
Old 12th August 2012, 06:12 AM   #2215
Send a message via Yahoo to ionutzxpo
Hi Thienchay,what output mosfet can i use for +/-80V ? i was thinking at IRFB5620 (25nC gate charge) because they are class d mosfets and they are easy to drive at high speed without overheating the driver IR2110.I build a CHE900 and with IRFP4227 and 1k at oscilator i had 500Khz oscilation but the IR2110 was very hot 60-65 degrees,so i change the R OSC at 470R and got exactly 300Khz IR2110 only 40 degrees but the sound on high's was a little under the veil like something was missing.
Old 12th August 2012, 09:45 AM   #2216
STAGE4 is offline STAGE4  Sri Lanka
STAGE4's Avatar
Default DIGITAL ANACONDA-up to 3000w
DIGITAL POWER AMP( up to 3000w ) ZDX - YouTube
Old 12th August 2012, 11:23 AM   #2217
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
ionutzxpo, is this the ROSC that you're talking about?
Old 12th August 2012, 11:42 AM   #2218
no! its the one betwen the 1N capacitors
Old 12th August 2012, 12:15 PM   #2219
paskal9's Avatar
ok. thanks for the information. never knew how to change the oscillation frequency in that design before.
Old 12th August 2012, 01:12 PM   #2220
thanks thienchay,
will be back with the response.......could u plz tell me why dint u use totem drivers????????/
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 94 16th February 2017 12:16 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 07:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 09:29 AM
Copyright ©1999-2017 diyAudio
