ucd 25 watts to 1200 watts using 2 mosfets
Old 9th August 2012, 04:23 PM   #2201
stewin is offline stewin  Kenya
Originally Posted by CPX View Post
Heating is due to deadtime form and effective delay,i do not think the amplifier in itself has a problem.
does dead time vary with voltage ? as in the more high voltage you use the more you have to adjust dead time.? and how cn one adjust ??
Old 10th August 2012, 04:35 AM   #2202
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Originally Posted by thienchay View Post
Thanks , you can show me that . Maybe i have some mistake
Thienchay,
Do yuo also have DIY files for the 12v bias regulator of IRS900D?...
thanks!
Old 10th August 2012, 05:50 AM   #2203
thienchay is offline thienchay  Viet Nam
thienchay's Avatar
Originally Posted by abeteer View Post
Thienchay,
thanks!
Yeah , i used LM317 for 1 Channel .
This my Layout and PDF file
File Type: pdf IRS-2000D 2 with LM317 regulator _ PCB.pdf (90.1 KB, 985 views)
File Type: pdf IRS-2000D 2 with LM317 regulator _ Overlay.pdf (112.0 KB, 940 views)
Old 10th August 2012, 05:57 AM   #2204
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default 12v bias regulator 2.5ampere
good regulator
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 10th August 2012, 08:24 AM   #2205
de Ocampo's Avatar
Thienchay,
Do you have the schematic? what was the appropriate values of R1 & R2?..
Andrew,
Can you post the construction details for 100uh inductor?
Thank you guys!
Old 10th August 2012, 11:55 AM   #2206
thienchay's Avatar
Thienchay,
Andrew,
Thank you guys!
You can see all Information of LM317 in datasheet , Vout = Vref (1 + R1 / R2) + I adj R2 .
You can calculate in this site : LM317 / LM338 / LM350 Voltage and Current Regulator Calculators
Old 10th August 2012, 12:50 PM   #2207
sweetperfume is offline sweetperfume  India
Thienchay,
your design gives positive 12v or 12v ref to negative supply rail.....
warm regards,,,,,
Old 10th August 2012, 03:42 PM   #2208
manojtm is offline manojtm  India
manojtm's Avatar
Hi All
LM317 can handle only 1.5A Max. Use LM350 for 2A if you need only 1A use LM7812(700mA -- 1A Max with heat-sink) its for single IRFP250 no problem my circuit work 90V supply i use 12V regulator 7812
Old 10th August 2012, 03:54 PM   #2209
thienchay's Avatar
Originally Posted by sweetperfume View Post
Thienchay,
warm regards,,,,,
Hi
+ (12V) on Regulator Board connect to +12V on Power board
.... and - (GND) on Regulator Board connect to COM (V-) on Power Board .
GND of Regulator must be connect to V- on Power Board .
Old 10th August 2012, 04:01 PM   #2210
thienchay's Avatar
like this
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
