ucd 25 watts to 1200 watts using 2 mosfets
Old 8th August 2012, 12:32 PM   #2191
sweetperfume is offline sweetperfume  India
does that design works with cd4049 perfectly with given rate of output
Old 8th August 2012, 12:37 PM   #2192
manojtm is offline manojtm  India
manojtm's Avatar
Hi thienchay,
you are not connected a diode from junction to -VE rail it is must for class d amp
Your PCB is look good
MANOJ
Old 8th August 2012, 03:01 PM   #2193
thienchay is offline thienchay  Viet Nam
thienchay's Avatar
Originally Posted by stewin View Post
are you sure it will work with that voltage?? what fets are you planning to use??
That information from Detex .
I 'll used IRFP460 .
regards
Old 8th August 2012, 03:12 PM   #2194
red_zone003 is offline red_zone003  Romania
At what rail voltage will give 1000w into 8ohm's ?
Old 8th August 2012, 03:15 PM   #2195
thienchay's Avatar
Originally Posted by manojtm View Post
Hi thienchay,
MANOJ
Thanks , you can show me that . Maybe i have some mistake
Old 8th August 2012, 03:18 PM   #2196
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
at 130v if you could swing it rail to rail and without any lack of current will give you 1056w into 8 ohm.
i do think it's better to bridge the 8 ohm if you're looking for that much power. 63v rail into 8 ohm bridged will yield 992w.
Old 8th August 2012, 04:27 PM   #2197
stewin is offline stewin  Kenya
by the way thienchay will you bridge the amp at that high voltage +/-130vlts.
Old 8th August 2012, 06:41 PM   #2198
guys i have decided to go back to basics fully discreet .i liked this amp but the only set back was it never handled well high voltage the outputs were heating . but if i have to bridge at low voltage like +/-55vlts i prefer this amp to the others here are my layouts . i have ordered smd resistors but before they arrive here is what i am up to. i will post components and bom later. have fun
Old 9th August 2012, 12:35 AM   #2199
CPX is offline CPX  Romania
Heating is due to deadtime form and effective delay,i do not think the amplifier in itself has a problem.
Old 9th August 2012, 12:53 PM   #2200
has anyone built this amp with success
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
