ucd 25 watts to 1200 watts using 2 mosfets
Old 7th August 2012, 11:36 AM   #2181
manojtm is offline manojtm  India
manojtm's Avatar
Hi stewin,
My old design, i was tested with common PCB and sound not good more noise so i discarded my design change to carrier based one. i use some part for my new class d.now i saw this thread it is great.so anyone can change this and design a good PCB don't ask me why i change L1 value(changing uH sound is good)some mistake is in my schematic i know that.Good luck
MANOJ
Old 7th August 2012, 12:46 PM   #2182
chago25 is offline chago25  Philippines
Originally Posted by stewin View Post
what voltage did you use and was the outputs heating ?
i use only 60 0 60vdc at 8 ohms. the mosfet still cold without heatsink only inductor coil has slight heat
Old 7th August 2012, 06:52 PM   #2183
stewin is offline stewin  Kenya
has anyone tried +/-90vlts dc
Old 7th August 2012, 10:19 PM   #2184
luka is offline luka  Slovenia
luka's Avatar
I used +/-75v and 4r with irfp4227 and zetex buffers between fets and IRS
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 7th August 2012, 10:32 PM   #2185
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
JBL use LM311 and NE555 for protect, amp use TL081 on input and inverters...
Old 8th August 2012, 09:27 AM   #2186
thienchay is offline thienchay  Viet Nam
thienchay's Avatar
My New PCB , IRS-2000D , will be IRS-3000D if used +/-130V .
Old 8th August 2012, 10:41 AM   #2187
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
willing to share the schematics and pcb? looks like 2 pairs of mosfet with totem pole.
wicked amp for low impedance load
Old 8th August 2012, 11:53 AM   #2188
thienchay's Avatar
Yeah , 2 pair mosfet for 1 channel , will load 2 Ohm at +/- 130V max , 3000W .
I'm not yes draw the sch , i can share my PCB , i'm remake of Detex IRS-3000D .
This is Layout
Old 8th August 2012, 11:58 AM   #2189
thienchay's Avatar
And PDF file ....
regards
Old 8th August 2012, 12:30 PM   #2190
are you sure it will work with that voltage?? what fets are you planning to use??
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 96 4th August 2017 09:40 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
